Old 05-03-2006, 07:57 PM   #1
Als454
Exclamation WTB parts to finish project!
Just finishing for parts before turning to a vendor. I need the following:
Right front fender for 72
Rear cross sill (wood bed)
Front bed panel(wood bed)
Wheel housings
P/S remote resevoir for big block
Also need the spring that is in the automatic Column (tilt) for the gear shift
Lost mine somewhere along the line. Does anyone know if this is the same spring as in the non-tilt column?
Thanks Allen.
72 Chevy A/C P/B P/S Tilt
454 Engine 400 TCI Trans
C30 Frame C10 Suspension
Short Wheel Base (Dually)
Als454 is offline   Reply With Quote
Old 05-03-2006, 08:12 PM   #2
greenhorn male
greenhorn male's Avatar
Re: WTB parts to finish project!
I may have the spring/s for the auto tilt, if you or someone can post a pic of this thing.
03 Tahoe
72 GMC Super Custom 2500 Custom Camper, my reliable workhorse. Dual gauged tanks, dual battery trays.
greenhorn male is offline   Reply With Quote
Old 05-03-2006, 09:21 PM   #3
Als454
Greenhorn, I don't have a picture. All I have is a distant memory of what it looked like before I lost it. Maybe someone else can come up with a picture.
Allen
Old 05-03-2006, 10:27 PM   #4
greenhorn male
Al, tell me if this is the spring. All the other little parts are also off a tilt.
03 Tahoe
Old 05-03-2006, 10:29 PM   #5
71SWBChevy
71SWBChevy's Avatar
the front panel you need for fleet or step?
Drew
'71 Chevy 350/TH350 Hugger Orange
Currently just a rolling frame, body work soon to follow!!!
Check out my Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=212927
Daily Driver: 1997 Chevrolet S-10 with more gears than pistons
71SWBChevy is offline   Reply With Quote
Old 05-04-2006, 06:37 PM   #6
Als454
Greenhorn, I believe that is the tilt spring, that one I have. The one I am missing is for the gear shift and is much smaller.
Old 05-04-2006, 06:38 PM   #7
Als454
71SWBCHEVY, the panel would be for a fleet side.
Old 05-04-2006, 07:53 PM   #8
greenhorn male
Is it these springs inside the housing?
03 Tahoe
Old 05-04-2006, 11:09 PM   #9
Hotrodhenryj
Truck Farmer
Hotrodhenryj's Avatar
Allen, I have one nice wheel housing and the BB reservoir. Both for $50 shipped. Chuck
Arizona rust free sheetmetal
Hotrodhenryj is offline   Reply With Quote
Old 05-04-2006, 11:22 PM   #10
Bob Moore
I have the tilt spring from inside the shift bowl. $6.50 to your door.
I can PM you my mailing address. Thanks - Bob
67 C-20 LWB, tilt, speed alert,
vac, 454, T400
67 C-10 SWB, factory air with
more to follow
Bob Moore is offline   Reply With Quote
Old 05-05-2006, 09:46 PM   #11
Als454
Hey Guys, Let me try to describe this spring a little better. It is the one that goes with the gear shift (selector lever). It is located under the very end of the lever where it extends into the column. When you pull the gear shift toward you to release it (shift) you are pulling against this spring.
Allen
Old 05-07-2006, 12:10 AM   #12
Bob Moore
Yes Allen, that is the one I can ship to your door for $6.50. 5/16 diameter by 7/8 long. It goes under the shift lever to provide tension putting the lever into the detent gate to prevent slipping out of Park and reverse without pulling on the lever.
Let me know - Bob
vac, 454, T400
more to follow
