Old 04-30-2006, 01:53 AM   #1
redneckdds
redneckdds's Avatar
Need front disc pics
We did the drum to disc/drop conversion and now the brake hose off the caliper hits prematurely on the crossmember... is this normal? anyone have any pics of their setup? maybe we installed something incorrectly
'67/70 Chevy C/10
'10 2500 Crewcab Duramax 4wd
redneckdds is offline   Reply With Quote
Old 04-30-2006, 08:31 AM   #2
Bowtie468
Bowtie468's Avatar
Re: Need front disc pics
Hopefuly these will help ! It's a complete 72 disc setup bolted up to my 68 frame. Early Classic drop spindles, Brake lines are s/s hard tube and s/s braided line from Inline Tube. Brake calipers are OEM.
If you need another angle, just let me know and i'll run out to the shop and snap it !
Chris
click here to see my buildpage
http://67-72chevytrucks.com/vboard/s...d.php?t=394656
1979 C10 Silverado Big10 SWB
Factory 454/400
Cardinal Red/Santa Fe Tan (original paint)
1969 Camaro X44 LS swap
1968 C10 SWB Fleetside (SOLD)
468BBC MultiPort TPI / Dynamic EFI P4
Black/Black
1963 Nova SS convertible (SOLD)
194 I6/ PowerGlide
Bowtie468 is offline   Reply With Quote
Old 04-30-2006, 11:26 AM   #3
68 short step
i too have a 68 and my hardlines run behind the front axle member ( if thats what its called)
and how my brake lines are ran
68 short step is offline   Reply With Quote
Old 04-30-2006, 08:21 PM   #4
redneckdds
redneckdds's Avatar
thanks guys... it looks like you both have them connected to the crossmember in different spots!! bowtie, your are connected in the front of the A-arm and 68... well, yours are in the same spot as mine, in the back of the A-arm... Will the hose pinch or get kinked when you turn the wheels all the way right/left?
'67/70 Chevy C/10
Old 04-30-2006, 10:19 PM   #5
68 short step
no not even close....
whats yours look like? we need pics of yours
Old 05-01-2006, 02:28 AM   #6
kevncar
Active Member
kevncar's Avatar
thanks for the pics guys. I am about to go through the same thing. Swapping 76 chevy discs on to my 67. My lines are behind like 68's I was worried I may have to get new lines. Looks like maybe not.
Kevin
72 Chevelle
67 C10...454/TH400
Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=193961
kevncar is offline   Reply With Quote
Old 05-01-2006, 06:32 AM   #7
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Stock corssmembers from 71 and 72 had the brake line tabs in front, all 70 and earlier trucks had them behind.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 05-09-2006, 11:52 PM   #8
redneckdds
redneckdds's Avatar
here are a few pics... these are the regular rally wheels 15x8 4 1/2" BS, with 265/70/15 tires. It looks good if its the rightside tire turned left or leftside tire turned right, hope that makes some sense
front left, turned hard left
front right, turned hard left
'67/70 Chevy C/10
Old 05-10-2006, 10:11 AM   #9
72 Cheyenne402
72 Cheyenne402's Avatar
Nice pics
72 Cheyenne402 is offline   Reply With Quote
