Like a Rock!
How do you hook up a trailer plug?
Does anybody know how to wire in a 4 pin trailer plug to our trucks?. One wire is for ground, one is for running lights, and the other two are left and right signals but how do you get the brakes to light up??
http://cgi.ebay.com/ebaymotors/BOAT-...QQcmdZViewItem
69 LWB Runs great - work in progress Mess with me and you mess with the whole trailer park! ![]() |
Re: How do you hook up a trailer plug?
Your brake light is the same as your turn signal light.
When it is blinking it is a turn signal. When it is constant on it is a brake light. So you got ground, tail lights, brake/left turn signal, brake/right turn signal.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
Like a Rock!
Thanks mrein3, that makes perfect sense. I should have thought of that!
![]() Join Date: Sep 2005
go to napa they sell a plug that you can plug inbetween the rear light plug then you just got to make a double sided tailer wire no cutting the truck wireing
#5 | |
Larry 1949 Willys CJ2A, Kubota Turbo Diesel engine, Warn Overdrive, 11 inch brakes, 12volt, Warn M8000 Winch "Little Green" 1970 Rustoleum Roller Red C20 Custom Camper 454 TH400 "Big Red" 1971 K20 6.2 Turbo Diesel 4x4 4spd Ranger Overdrive "Pumpkin Wagon" 2005 VW Beetle Diesel 44+ MPG "Silver Bullet" |
#6 | |
Licensed to Thrill!
its all about the +6 inches
The napa one is less than 10 bucks IIRC, walk into any NAPA and tell them to get you a p/n 755-1554
![]() Join Date: Jul 2004
Double yes on the plug, don't butcher up the wires if you can avoid it.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 |
#9 | |
The LuvShack Garage
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Big Piggy: "Goliath" 07 Kodiak C4500 Lil Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
#10 | |
blood type; Retumbo
umm maybe your walmart my walmart don't lol
i wish someone told my trucks po about theses t conectors they are great
common sense isn't so common anymore |
#13 | |
67-72 Addict!
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
