Old 05-14-2006, 02:13 AM   #1
moneyeater
moneyeater's Avatar
Re: How to lower my ride? Please help a newbie.
Wow thats very low compared to my 4/6 drop!In front i´m running 265/50/15 on alcoa design wheels in 10x15 ET -45 and still the rim rubbed a little at the lower a-arm!I had to grind the lip of the arm and the fit is tight!Maybe the tire will hit the fender too when the front dives in at hard cornering or breaking!Rearward i run the same rims with 295/50/15 tires and there should be no rubbingproblems!And on top of that all the local TÜV (technical inspection) may not give his " amen " to the suspension mods because the frontcrossmember is very low and may hit roadbumps!
Name:  rechte Seite.jpg
But besides all that your rideheight is coool!
moneyeater is offline   Reply With Quote
Old 05-14-2006, 08:56 AM   #2
los-lowrider
los-lowrider's Avatar
I think with my rims it won't work. At the moment it's not possible to turn. So what do you think could i use. What backspace etc. is possible to drive?
Best Regards from Germany!
www.los-lowrider.com
los-lowrider is offline   Reply With Quote
Old 05-14-2006, 08:59 AM   #3
los-lowrider
Oh I forgot, I think I have to keep a diameter of 28" because the ground clearance is just a package of cigarettes. So if I loose in diameter the lower arm will scrap.
Old 05-14-2006, 04:32 PM   #4
SCOTI
SCOTI's Avatar
Then 225/75-15's will net you just over 28" tall. Unfortunately, you'll more than likely buzz the top of the inner front wheel-wells w/that tall of a tire.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
