Old 05-16-2006, 01:37 PM   #1
AWEGS72
AWEGS72's Avatar
Remove ac components?
My truck originally came with ac,but PO removed ac compressor. I have the condensor/evaporator..etc. SHould I remove them or try to complete the system again?
AWEGS72 is offline   Reply With Quote
Old 05-16-2006, 09:28 PM   #2
longhorn70gmc
longhorn70gmc's Avatar
Re: Remove ac components?
Only redo it Original if that is what way you are going with your truck. There are Cheaper better replacements out there. I went back Original but haven't finished it yet.
Respectfully
Billy
1970 GMC Sierra Grande 402/TH400
(Longhorn)14 years and counting rebuild!
1975 (Build) Chevrolet SWB 4X4 350 SB Lifted 6 inches
1970 Ford F250 Ranger 390 BB
2010 Ford Super Duty F250 XLT W/4 inch lift kit and Pro Comp Tires
Hub Cap Freak!
I need another truck like I need another hole in the head!
I'M IN THE MARKET...AS IT WERE!
longhorn70gmc is offline   Reply With Quote
Old 05-16-2006, 09:44 PM   #3
wibilly
wibilly's Avatar
i'm going to try and get my oraginal up and running all there but the compressor. i understand there are better systems avalible reasonable ,but wheres teh challange in that
common sense isn't so common anymore
wibilly is offline   Reply With Quote
Old 05-16-2006, 11:13 PM   #4
stope4
I'd rebuild the original. It's as good as the newer systems, may not be as efficient but as functional. If you believe you need empty space under the hood, more noise in the cab and foggy windshield in the morning then the newer systems are the way to go. If you like the way the original system looks under the hood and an ac and heater that works very good, then that's the way to go.
stope4 is offline   Reply With Quote
Old 05-17-2006, 09:02 AM   #5
AWEGS72
AWEGS72's Avatar
So, basically what you are all saying is I should one way or another complete the system. Not remove the remaining pieces.
Old 05-17-2006, 09:11 AM   #6
JMac11
JMac11's Avatar
Dance with what brung ya..... P Bryant
An hour and a test light, I have mine working after decades of non use...... but I got lucky
JMac11 is offline   Reply With Quote
