MEMBER
WTB. k/5 r upper hatch hard wear only
I have a good hatch and tee handle with both side supports. I nee inside rods and both side latch pieces that bolt to hatch and lock and release I think I have every thing else.
86 sub 4wd, 1 ton, duallie, big block th475 72 c10 short fleet, pro street 72 K/5 blazer,2x4 almost stock 72 3/4 ton sub 4x4 61 morris minor pickup, chevy 4.3 v6 03 escalade, 24" momo's wifes 96 2wd 2door tahoe 67 2wd suburban 72 4wd k5 99 vortec 14bolt/d60 205/th400- 72 4wd crewcab 1 ton sb cummins allison -2012 2ss camaro black hard top- 8 yamaha quads- 05 4wd one ton duramax dually, family limo. ![]() |
![]() Join Date: Apr 2000
Re: WTB. k/5 r upper hatch hard wear only
i got them,hows 20.00 and shipping??
if interesed send me a pm
jamie72 72 BB cheyenne -- Restoration getting started.. member #807 http://www.myspace.com/whitetailobsession www.antlertalk.com |
The LuvShack Garage
OFF TOPIC - Your Siggy
What is a 71 K2 Blazer? ![]()
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Big Piggy: "Goliath" 07 Kodiak C4500 Lil Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T Last edited by LUV2XCLR8; 05-16-2006 at 06:52 PM. |
MEMBER
luv2xclr8..I have heard the 2wd drive blazers called k/2 and i've also heard them called c/2 ...but they are definately not k/5 ....Can any body shead some light on this subject....
MEMBER
jamie72...Thank you for the quick response ....pm sent
I guess the name thing is kinda odd.They`re all called K/5 on the nameplate.But,technical a 2wd Blazer would be a C/5.Just like in 69/70 when a base level truck was a C/10 or C/20 on the nameplate,even if it was a 4wd K/10 or K/20.So,those would be a C/10 K/10,etc.So,I guess a 2wd Blazer would be a K/5 C/5.If I had a 69/70 base truck,I`d call it a K/10 and ignore the nameplate,basically it`s got no name.If I had a 2wd Blazer,I`d call it a C/5,right or not.That says what it is in my mind,that`s what names are for.It`s like my`90 Blazer,screw GM`s name,it`s a K/5,not a V1500.
Not a bad nut after all..
I have both rods only (cheap) if you need them.
'05 Chevy 2500HD 4x4 '72 GMC LWB 4x2 driver '72 Chevy LWB 4x4 plow truck '71 Blazer 4x4 driver '70 GMC LWB trailer |
MEMBER
badpeanut...I think i've got it covered from ''jamie72'', But thank you just the same. I still may end up needing them so ill keep you posted.
MEMBER
jamie72...problem with ebay address..pm sent...local13hutch...
