Old 05-18-2006, 10:30 PM   #76
Jebb1978
Jebb1978's Avatar
Re: Jebb's Project 1959 GMC
Cleaned and painted most of the rear frame today. I removed all the E-Brake stuff that has not been hooked up since the rearend swap.
1959 GMC project
Jebb1978 is offline   Reply With Quote
Old 05-18-2006, 10:41 PM   #77
Jebb1978
Jebb1978's Avatar
Also installed the flip kit just to get an idea of how it worked and how everything will line up. I got stuck because the kit changes the way the U bolts mount to the rear end. I got new U bolts that are longer and will work but the plate that they bolt to is different also now. I am going to the junk yard tomorrow to get flat ones so I can bolt it together. I looked at my Dad's 83 pickup and it has the right kind so that's what I am looking for.
1959 GMC project
Old 05-18-2006, 11:23 PM   #78
dwcsr
Hollister Road Co.
dwcsr's Avatar
just weld in that C clamp. it will put the thrill back into driving.
Old 05-19-2006, 12:20 AM   #79
Jebb1978
Jebb1978's Avatar
Hmmm, I am trying to keep the thrill factor to a minimum.
1959 GMC project
Old 05-19-2006, 12:23 AM   #80
jsbgump
Gone Fishing
jsbgump's Avatar
ah cmon shawn live a little
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop Frame of resto has been started
2022 Hyundai Tucson Limited
2019 Chevy Traverse Redline Edition Wifes Ride
Build Thread
http://67-72chevytrucks.com/vboard/s...=1#post3483616
jsbgump is offline   Reply With Quote
Old 05-19-2006, 12:30 AM   #81
CAL 58 GMC
CAL 58 GMC's Avatar
Nice work buddy! Are you notching the frame?
CAL 58 GMC is offline   Reply With Quote
Old 05-19-2006, 01:38 AM   #82
Jebb1978
Jebb1978's Avatar
Thanks Cali, the C-Notch is coming soon. A friend of mine's Dad is going to let me bring it to his house for that. He has everything I am going to need to do it plus he is going to help out. I need to get the rearend set up first so I can calculate the cut better. It will also need to get all 4s touching ground again and that's gonna take some money that I don't have just yet.
1959 GMC project
Old 05-19-2006, 07:33 AM   #83
entourageguy
Yellow truck club
entourageguy's Avatar
It should roll nice on those red rims!!
Brian ......
My hub garage address
http://www.hubgarage.com/mygarage/59apache
I gue$$ everything has it'$ price
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
350 700r lokar shifter
power MII front end, shockwaves
tilt, 4 wheel discs
4-link and bags
10 bolt limited
entourageguy is offline   Reply With Quote
Old 05-19-2006, 11:07 AM   #84
Ice68
Ice68's Avatar
NICE!!! Keep up the good work!
We got the cab off our '59 Chevy Truck frame. We cleaning up the frame.
'68 Chevy Truck C10 LWB 292 engine 3spd Tranny Everything Stock except for shaved bodywork.
'72 Chevy Truck Custom Deluxe 2WD LWB 350/350 HEI Tilt PS AC Dual Exhaust
Ice68 is offline   Reply With Quote
Old 05-19-2006, 01:52 PM   #85
Apache
Apache's Avatar
Nice work
54 Chevy Bel Air 4dr powerglide
54 Chevy SWB
58 Chevy Big Window SWB Fleetside project
58 Chevy LWB 235/4spd
76 Chevy Nova 350/TH350 4.88's *10kmiles on "new" engine
79 Chevy 4x4 SWB 350/4spd 3/4 ton
81 Mazda RX7
84 F@!d Mustang
96 F@!d Ranger 2.3L/5spd
Apache is offline   Reply With Quote
Old 05-19-2006, 07:51 PM   #86
Jebb1978
Jebb1978's Avatar
Thanks guys, got my junk yard tresures today so I am off to work again on Monday.
1959 GMC project
Old 05-23-2006, 09:57 PM   #87
Jebb1978
Jebb1978's Avatar
Wow it's low!!!! Flipped rearend and 2 inch lowering blocks. I think it may be a little lower than the front is going to be with the motor in. Only time will tell i guess?????
1959 GMC project
Old 05-23-2006, 10:00 PM   #88
Jebb1978
Jebb1978's Avatar
More!
Moched her up a bit just to take a look. Aslo got the non power steering box cleaned up and mounted.
1959 GMC project
Old 05-23-2006, 10:01 PM   #89
Jebb1978
Jebb1978's Avatar
1959 GMC project
Old 05-23-2006, 10:18 PM   #90
dwcsr
Hollister Road Co.
dwcsr's Avatar
That’s going to look good at that height
Old 05-24-2006, 06:53 AM   #91
CAL 58 GMC
CAL 58 GMC's Avatar
Look's good buddy!!! Did you get the flip kit on the rear taken care of?
Old 05-24-2006, 11:25 AM   #92
Jebb1978
Jebb1978's Avatar
Yes Sir! This is just how it is going to bolt together. It is all coming apart again for the C Notch and new leafs. As you can see it also needs some clean up work. I am really happy with the stance!!!
1959 GMC project
Old 05-24-2006, 05:39 PM   #93
jsbgump
Gone Fishing
jsbgump's Avatar
Thats stance will look sick when completed.
Build Thread
Old 05-24-2006, 06:53 PM   #94
Ice68
Ice68's Avatar
Jebb,
Nice job on your project! I'm working on my '59 Chevy. What brand of paint did you use on your chassis? Did you primed the frame before you painted it black?
Thanks,
Leroy
Old 05-24-2006, 07:24 PM   #95
Igotachevyor2
Apache Club
Igotachevyor2's Avatar
looks good
58 CHEVY APACHE I 74 CHEVY C-10 I 78 K-10 donor truck I 89 SONOMA
My Trucks Apache Sitting Idle MySpace
Project Dad's Truck (74 C-10 to K-10 conversion)
Igotachevyor2 is offline   Reply With Quote
Old 05-24-2006, 08:10 PM   #96
Jebb1978
Jebb1978's Avatar
Originally Posted by Ice68
Jebb,
Thanks,
Leroy
No priemer needed, this is good old fashion Rustolium High Gloss! I used it on my last truck frame and found it to be very durable. I am sold on this stuff. It's cheap and you can buy it anywhere!!!! You should start a thread so we can watch your progress.
Thanks for all the compliments guys!
1959 GMC project
Old 05-24-2006, 08:37 PM   #97
dwcsr
Hollister Road Co.
dwcsr's Avatar
I used that same stuff except I also used their primer that is for slightly rusty metal
Old 05-24-2006, 10:33 PM   #98
Apache
Apache's Avatar
Nice stance, looking good Jebb.
I agree, always nice to see other people's talents and to watch a ride take shape.
54 Chevy SWB
81 Mazda RX7
84 F@!d Mustang
Old 05-25-2006, 06:02 PM   #99
Ice68
Ice68's Avatar
Thanks Jebb1978 for the reply. I started my thread for my '59 Chevy Truck. I will add pictures at a later time. I purchased the Dupont Nason Chassis paint, but I was not sure if it needed to be primed. I'm learning as I pursue a frame-up restoration. Thanks for the info for the Rustolium paint.
Thanks,
Leroy
Old 05-25-2006, 09:53 PM   #100
Jebb1978
Jebb1978's Avatar
Good luck Ice!
Thanks Apache, get off your drunken butt and get some work done!!!!
1959 GMC project
