Old 05-17-2006, 08:11 PM   #1
outlawchevy
outlawchevy's Avatar
bb mount ?
can you bolt a bb on the same towers that where for a sb thanks for any help you can give
(If all else fails get a bigger hammer)
outlawchevy is offline   Reply With Quote
Old 05-17-2006, 10:50 PM   #2
kelsfine69
18 Till I Die
kelsfine69's Avatar
Re: bb mount ?
dont think so, I used bb towers with sb mounts ,but it sits in the bb position.
2011 GMC Acadia
1969 GMC BBC LS7
2007 GMC Crew Duramax
1987 Camaro Iroc 350 Tuned Port Injection
42000Km
1987 Chevrolet Silverado 350 TBI
1987 Chevrolet Silverado 350 TBI(yes 2)
Take me drunk, I'm too home...
kelsfine69 is offline   Reply With Quote
Old 05-17-2006, 11:27 PM   #3
longhorn70gmc
longhorn70gmc's Avatar
Re: bb mount ?
I did the same thing back when I rebuilt the motor. It caused my BB to sit a little to the Driver side a bit. That causes the Fan shroud to be off as well. Works just fine for now and I will eventually replace them with the real Mcoy.
Respectfully
Billy
1970 GMC Sierra Grande 402/TH400
(Longhorn)14 years and counting rebuild!
1975 (Build) Chevrolet SWB 4X4 350 SB Lifted 6 inches
1970 Ford F250 Ranger 390 BB
2010 Ford Super Duty F250 XLT W/4 inch lift kit and Pro Comp Tires
Hub Cap Freak!
I need another truck like I need another hole in the head!
I'M IN THE MARKET...AS IT WERE!
longhorn70gmc is offline   Reply With Quote
Old 05-18-2006, 03:44 PM   #4
farmtruckIII
71 GMC 454/TH400
farmtruckIII's Avatar
Re: bb mount ?
swap the frame mounts side to side, you will have to tweak them a bit like I did, but it works, some headers may not work w/o dimpling though.
"The bigger you are the harder you fall, the farther you walk the longer you crawl."
farmtruckIII is offline   Reply With Quote
Old 05-18-2006, 04:04 PM   #5
boraxman
Keepin an eye out
boraxman's Avatar
Re: bb mount ?
Now theres some good info
1970 Chevy C10 SWB 5.3
1996 Toyota Tacoma SR5 4x4
2007 Vespa GTS 250 Scooter
ZIP 91351
boraxman is offline   Reply With Quote
Old 05-18-2006, 05:36 PM   #6
farmtruckIII
71 GMC 454/TH400
Re: bb mount ?
I had hell getting things to line up, but it eventually worked. You will have to drill the lower holes, and you may curse alot lol, but I have got mine setting pretty.......I can't wait for the flaming about my radiator being too tall.
Old 05-18-2006, 05:53 PM   #7
1970 CST Short Wide
Senior Moment
1970 CST Short Wide's Avatar
Re: bb mount ?
Your radiator is too tall.
Sorry couldnt resist
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN
2013 GMC PU, Oldest Son
71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son
2019 GMC Diesil Dually. Youngest Son
2017 Toyota SUV Daughters car
2018 Traverse , Wife’s Ride
Pittsburg Ca
94565
1970 CST Short Wide is offline   Reply With Quote
Old 05-18-2006, 07:06 PM   #8
ratfreak88
Re: bb mount ?
hey your radiator looks like mine. its out of a 77 1/2 ton. just fabbed some brackets
ratfreak88 is offline   Reply With Quote
Old 05-18-2006, 07:33 PM   #9
farmtruckIII
71 GMC 454/TH400
Re: bb mount ?
Got any pics?
Old 05-19-2006, 04:34 PM   #10
68racer
Yeah baby!
68racer's Avatar
Re: bb mount ?
I just fitted the BB on the I6 mounts, now that is tight! Had to cut the firewall on the drivers side and notch the mount to fit the headers but I wanted the most set-back I could get.
11.37 @116
68racer is offline   Reply With Quote
