gauge cluster lights
hey guys, i just bought a great shape 71 c10 fleetside. all electric components work fine, except for the gauge lights. i replaced all the bulbs. the high beam indicator works fine, as well as turn signal indicators. circuits are fine on back of instrument cluster. any ideas? if someone had a schematic for the head light switch/ cluster, that would be great. thanks in advance!
1970 GMC
Re: gauge cluster lights
I wish i could help you, My high beam indicator light went out, and I haven't a clue how to fix it.
MadDog's Website |
67-72 Addict!
Welcome to the board from a fellow Marylander!. Does this help?:http://67-72chevytrucks.com/vboard/s...d.php?t=185665
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
Woof?
Wazoo: check to make sure that your parking lights are working, too. The parking lights and dash lights work off the same fuse, and the same part of the headlight switch. If your parking lights are okay, then it's probably the variable resistor build into the headlight switch .. aka the dimmer. Ignoring the blatantly obvious (making sure the headlight switch is turned counter-clockwise almost all the way,) you may have to replace that switch.
MadDog: the light probably just burned out. There are little twistable bases that fit into the back of the cluster that you can turn and pull out. Find the right one, pull it out, and check the bulb.
1968 LWB CST BB 2004 Avalanche Z71 LT3. 2003 S-10 ZR2 (hers). 1997 Astro 1992 Caprice wagon, 500k stock miles. Nursing wounds after a bad wreck. 1997 Saturn - need gas mileage from something! |
got it working. thanks everyone.
