Old 05-23-2006, 01:12 AM   #1
EFI70Blazer
Active Member
EFI70Blazer's Avatar
Rally Wheel Widening
Just curious where i can get my Truck Rally Wheels widened or buy some that are already done for the 6 lug pattern. I put 35x12.5x15 tires on my 8 inch rims and they just look wrong. I need them to be 10" for them to spread out and look right. What have you guys done? Any idea what they might cost?
Mike T.
Oregon
70 GMC Jimmy 4x4
70 Camaro LS1 plans in the works
71 RS/SS Camaro numbers matching
86 Chevy Silverado SWB 4x4 (454 merlin heads, 3/4 running gear upgrade, Detroit lockers front and rear)
EFI70Blazer is offline   Reply With Quote
Old 05-23-2006, 07:12 AM   #2
BobbyK
BobbyK's Avatar
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
Re: Rally Wheel Widening
Did a quick search...here are a few I found.
http://www.stocktonwheel.com/wheel_widening.htm
Looks like these guys have what you want in stock.
http://www.stocktonwheel.com/light_truck_wheels.htm
http://www.weldcraftwheels.com/
http://www.internetalternatives.com/wshoppe/wwiden.htm
http://www.winnipegwheelworks.ca/services.html
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension.
Petrolia,Ontario,Canada but working in Port Huron,MI.
See ALL my Blazer pic's HERE
BobbyK is offline   Reply With Quote
Old 05-23-2006, 07:58 AM   #3
vtblazer
vtblazer's Avatar
If it looks wrong to you, then by all means get them widened but 12.5's are run on 8" wheels all the time.
Fact is, if you wheel with it, the tire will protect those rims better with an 8" than a 10" wide wheel.
Consider this also, with a 10" wheel and 12.5's you'll BARELY fit inside the wheel wells on a car trailer. (don't know if you trailer) but it's good info to ponder on.
Watch the tire pressure (not to high) so you don't wear the centers and you'll be all set running that combo. JMO.
vtblazer is offline   Reply With Quote
Old 05-23-2006, 04:10 PM   #4
detroit72k5
detroit72k5's Avatar
I just put 35s on my 8" wheels last week and think they look great.
detroit72k5 is offline   Reply With Quote
Old 05-23-2006, 04:22 PM   #5
Billla
Billla's Avatar
I have 15x8 Ralley's on my '72 pickup. Wheel Vintiques (http://www.wheelvintiques.com/) makes just about anything you can think of - any size, any width and in any bolt pattern...and will custom-make wheels as required. The "stock" sizes are pretty cheap - think I paid $58 apiece for my 15x8s, another 28 for the trim rings and I had centers from my Corvette.
Billla is offline   Reply With Quote
Old 05-23-2006, 04:42 PM   #6
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Mine are on 8' also, but 10's look wicked, member here w/ 10's
on a Orange / White blazer and they do look more filled out
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 05-23-2006, 05:18 PM   #7
EFI70Blazer
Active Member
Thanks for the help guys. I just like my tires to look more filled out like they are suposed to be. A buddy of mine has 15x10 truck rally wheels on his 72 pickup. Same tire and wheel setup as mine, but his tires actually look 1 1/2 inches wider and more symentrical looking. He got his at a swap meet so i knew it could be done, but was not sure where. Looks like i will be adding that to the list of things to do.
Mike T.
Oregon
70 GMC Jimmy 4x4
Old 05-23-2006, 05:21 PM   #8
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Stockton widens them, and sells them in a 15 x 10 rally
