I called a machine shop today about a driveshaft for my c-10. I am using a vortec 350 along with a late model 5 speed. His quote"if you build it right it does not need balancing" his only condition was for street use not on the dragstrip. This is a shop specializing in driveshafts, he told me they have built all types for all types of applications. This shop is in Tupelo about an hour drive from my home. My only other choices is Memphis or Jackson which is 2.5 hours from both.
Lets hear from the board members. Thank you for your input.
ongoing 1970 c 10 lwb ![]() 1994 z-28 few mods.-owned since new ![]() 1978 vette silver/grey 25th anniv. paint ![]() |
Re: "If you build it right it does not need balancing"
He is the man you want. They balance them when they build them.
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer Last edited by jhow66; 05-22-2006 at 06:17 PM. |
Cantankerous Geezer
![]() If you do everything right when you build a driveshaft, it will not need balanced. Production built shafts need balanced because of the accumulation of tolerances, and balancing being cheaper than tightening the tolerances.
Fred There is no such thing as too much cam...just not enough engine. ![]() |
The machine that balances drive shafts is very expensive. The reason they tell you they don't need balancing is because they can't.If you are spending good money on a drive shaft why not get it balanced? The drive shaft turns pretty fast and it doesn't take much to make a vibration. Even if you can't feel it, it's still there causing damage. Chris
its all about the +6 inches
and in an overdrive aplication, the ballance is even more important since it spins faster than the crank. While there is some truth to what he says, I say don't risk it.
67 is sold
I believe more in 'Do it right the first time'
#7 | |
Aluminum slot wheels rule...
I had a driveshaft built and it vibrated all to h e double hockey pucks.I asked if they balanced it.They said,"no,we aligned it."Well anyone that can do as balanced weld on a driveshaft should be a god!I went out and bought a new driveshaft.
So that is 2 for no need to balance and 5 for balancing.
Any of you south MS guys know of a shop in Jackson or Meridian that balances and builds driveshafts.
Cantankerous Geezer
My statement was assuming he used a balance machine to check his work. I'll still say a well-built shaft won't need balancing, but it does have to be checked.
Still Green but learning
I know nothing about this subject, but that give me an advantage;-)
If you build it right it does not need balancing, but how do they know they built it right. If he has a balancing machine on site and will check it after complete go for it, and he is your man. If he does not have a machine then he cant claim to have done it right... truth is he wont know.
-- Cory 71 Cheyenne 10 - SWB, 350, "3 on the tree" AC cab 07 Suburban LTZ 4x4 2010 Acura TL 98 Mastercraft "FrankenStar" 225 27253 UPS/USPS IIOY....nope never was |
![]() Join Date: Jan 2005
He sounds more like a salesman than a machine shop guy. I'd opt for balancing. You want it right, not cheap...and have to do it over again. Sometimes you get what you pay for...
Case in point: when my 350 cracked block, my engine builder recommended that I just get a GM crate instead of bringing engine to him for sleve and rebuild. Took money out of his own pocket because it was the right thing to do.
'72 Chevy K-20 Crate 350, SM465, 4.10's |
I worked at a drive shaft shop. I would be interested to see a "well built" shaft that doesn't need any balancing.
"A true hotrodder wouldn't be content untill he had created a car so violent, so hairy, so totally sick that the very act of dropping the hammer would result in instant death. Anything less results in the need to go faster." - Tony DeFeo |
Oilfield Trash
Me and my buddy extended his driveshaft in his 84 mud truck after lifting it, just strapped it to a chunk of angle iron ,welded another chunk of smaller shaft into it and i swear on my life the shaft did not vibrate at all.
14 Dodge 3500 Mega Cab 08 Dodge 3500 Mega Cab 87 Chev 3+3 4x4 80 GMC K10 High Sierra bone stock 70 Chevelle 350SS long term project 68 GMC 3ton Grain Truck/Garbage wagon 50 Pontiac 2 Door Coupe Project "I've got a shotgun rifle and a 4 wheel drive and a country boy can survive" Hank Jr. |
#15 |
RIP Mr Ron
![]() Join Date: Dec 2005
This is a little out of the way for you but they have the parts and equipment to build drive shafts for anything from a go cart to a earth mover. The name is Wiles Welding in Paris Tn. 38242 The phone number is 731 642 2777. They build drive shafts for late modal dirt track cars and drag cars also. If you gotta have it they can make it happen.
Ron (Mr Round Tuit) ![]() Be kinder than necessary, for everyone you meet is fighting some kind of battle TN Message Forum TN Facebook Group SETN Truck Show My Photobucket |
#16 | |
More Cowbell....
http://www.67-72chevytrucks.com/vboa...d.php?t=200271 ERIC
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket Last edited by Putter; 05-23-2006 at 09:13 AM. |
#17 |
![]() Join Date: Jun 2002
I can second Ron on Wiles in Tennessee, they do great work...
Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 |
#18 |
Putter you have a pm, reply if you have a chance.
