KEEP ON TRUCKING
wtb eaton ho52 gears
i need a set of spider gears for a 71 eaton ho52.
may be interested in a center chunk or whole rearend if real close to martinsville va so i could pick it up. or does anybody what 14bolt would bolt right up thanks
72 cheyenne 2wd lwb 71 k20 sons bassett va |
Re: wtb eaton ho52 gears
The full floater 14 bolt spider gears will bolt into the eaton, you just need to change to the 14 bolt axles. I do have lotsa spare parts, just too far away.
KEEP ON TRUCKING
thanks would you happen to have just the spider gears shipping shouldnt be to bad on them
I have a set of 4.56 gears here. thats all i have for now. Bakersville NC
#5 | |
KEEP ON TRUCKING
just the ring/pinion or do you have the spider gears
i have a 71 3/4 2wd that im parting, would this be correct for you? im not that familiar with the 3/4 tons. im in Ringtown Pa. Thanks, Devin
68 chevy 406 small block, budget drag racer, new best e.t 11.91 @112 67 nova numbers matching 327 4 speed 13.6 @ 102mph 70 longhorn c-30 402/4 speed 70 c-10 swb 402, muncie 4 speed 94 s-10 350/th350 3:73 posi 71 c-20 402/th400 towrig for racetruck. 72 4wd lifted on 35's 72 350/3 speed winter beater |
#7 | |
I tell ya what i'll do.... If you haven't been handled yet..
I have some used ones in good condition.. I'll send them to your house for $30.00 I can get you pics but would be a day.. You can ask others.. I can be trusted..
Support The Board |
#9 | |
KEEP ON TRUCKING
right back at ya
Support The Board |
Active Member
If you do eventually upgrade to a 14 bolt full floater, 1 ton single wheel rear ends bolt right in without having to modify the perches. The 3/4 ton 14 bolts have wider spacing and have to be moved.
Mike T. Oregon 70 GMC Jimmy 4x4 70 Camaro LS1 plans in the works 71 RS/SS Camaro numbers matching 86 Chevy Silverado SWB 4x4 (454 merlin heads, 3/4 running gear upgrade, Detroit lockers front and rear) |
