10-08-2002, 06:59 PM | #1 |
Goodbye Darlin'
TPI swap... fuel line? Filter?
I originally posted this on the engine&drivetrain board but I know more of us look here so... When I make the swap from carb to EFI can I use the factory hardline (from my 71 Blazer)? For the return line I believe I'll need a larger diameter than originally used. Where would I look to find flexible line without the high price of braided steel and a reasonably priced (high pressure) fuel filter?
1971 Blazer CST SOLD! |
10-08-2002, 10:13 PM | #2 |
Old member
71 TPI
I have had a 86 305 H.O. TPI in my 71 since 89. The filter is nothing, just buy it for what ever year motor you use, the lines can be made up from any good hydrolic hose maker. You should be able to use the line already there for the return. If I'm not mistaken you can buy rubber hose now that will hold up to the high pressure of TPI also at local part stores. Hope this helps.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
10-09-2002, 03:49 AM | #3 |
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
I did the TPI swap 2 years ago on my 71 Blazer.I used the orig. blazer tank and orig. 3/8ths feed lines.
I spliced in the pump and filter inline on the 3/8ths feed line. I used 5/16ths hard brake line for the return and ran that down the drivers side frame rail. I also switched all the rubber lines to F.I. rated rubber lines(they take much greater preassures) Click the link to see all the pic's I took during the TPI swap. http://www.imagestation.com/album/?id=4292391623
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension. Petrolia,Ontario,Canada but working in Port Huron,MI. See ALL my Blazer pic's HERE Last edited by BobbyK; 10-09-2002 at 03:51 AM. |
