Old 06-05-2006, 02:36 PM   #1
boundstaffpress
Jamie Hyneman is my twin
boundstaffpress's Avatar
Front Drive Shaft
My front drive shaft was rattling and clanking, and shaking the hole truck when I bought it.
I decided to change the U-joints, and discovered that the CV ball and seat are eaten to nothing. Where can I buy a new shaft, or is it possible to have this one rebuilt. The slip joint is pretty worn on mine too. It may not be worth rebuilding.
I saw a front shaft in LMC, but don't really trust them. Any other possibilities?
thanks for your help.
Justin
SOLD 1967 K10 Fleetside, 283, Front and Rear Posi SOLD
Color Wiring Diagrams Now in High Resolution
V8 and Cab and Cab and Chassis
boundstaffpress is offline   Reply With Quote
Old 06-05-2006, 03:48 PM   #2
JAKES 68GMC
Aluminum slot wheels rule...
Re: Front Drive Shaft
I got my front driveshaft lengthened out as Brake Service, and they thought my CV was bad and it would cost about 200 bucks to fix. But, the counterman being the genious he was,he got looking at the shaft and saw that it a was just a u-joint gone. He even gave us a free u-joint to put in.
So yeah they can be fixed, but it will be pricey. I think LMC has the parts to fix it up, but they cost quite a bit. I'd start heading to junkyards or looking around the for-sale section. Note that if your truck has a Rockwell t-case, a NP205 shaft will NOT work, it's too long. You need the Rockwell drive shaft. Good luck.
Jake
JAKES 68GMC is offline   Reply With Quote
Old 06-05-2006, 07:45 PM   #3
1969 GMC
1969 GMC's Avatar
just take it to a reputable driveshaft shop. i was lucky enough to get a discount through my dad's account, but it wouldnt have been too pricy anyway. it was only slightly over $100 about 3 years ago.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 06-05-2006, 11:39 PM   #4
GMCMAX
Active Member
GMCMAX's Avatar
If the tit that the ball goes on is not eaten up, the CV kit from NAPA has the yoke/ball combo in it, at least the newer trucks I've worked on have. The machine shops here can cut off and replace bad ends.
Never try to teach a pig to sing; it wastes your time and annoys the pig!
Gets More Chicks
My lugnuts require more torque than your honda makes!
68 GMC, 4X4 conversion w/73 k20 running gear and springs, 350 4spd, 4.10's, D44 powerlok front, 14BFF govlock rear, 33" tires, lifted 4".
GMCMAX is offline   Reply With Quote
Old 06-06-2006, 02:24 PM   #5
boundstaffpress
Thanks guys. I will have to do some looking for a machine shop, and talk to the guys at NAPA. If anyone else has ideas, I'd like to hear them.
Justin
