PROJECT 7DEUCE
![]() Join Date: Dec 2002
Guys with leds..... what flasher are you running
anyone have a part ###### need some help with these things so that they finally work right..
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
its all about the +6 inches
Re: Guys with leds..... what flasher are you running
I don't have the P?n here, but I got mine from NAPA, just ask for a 2 prong electronic flasher. They sell quite a few of them, so they should have it on hand. You MIGHT need 2, check to see if your 4 way flashers work, if not, get that one too. (exact same part)
More Cowbell....
Heck, mine isn't even electronic. I do believe it is heavy-duty (like for use with trailers). I will see if I have a part number on it.
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket |
67-72 Addict!
I use an EL-12 to run all 640 LED's
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
PROJECT 7DEUCE
I have 2 el-12 flashers and the damn lights still dont work right and a few of the leds are burnt out agian.... I e-mail ece to see what I could do..
Old Skool Club
![]() Join Date: Jun 2001
Older flashers depend on current draw to heat up the switching mechanism. LED's don't have enough draw to heat 'em up. So, you gotta use electronic flashers.
I have been running a pair of 1157 replacement LED bulb assemblies, that I paid dearly for, almost five years ago. I put in an electronic flasher and have had no problems. But, I'm still running incandescent bulbs in the front, so they provide enough current draw for the turn signals and the 4-way's. I know that an old board member used to make the assemblies that ECE now sells, but I'm hearing that several buyers are having trouble with them. Personally, I'm from the old K.I.S.S. school, and the bulbs I use are bright and trouble-free. Some folks don't like paying nearly $100 for a pair, but with five years of trouble-free usage, I'm feeling like I did the right thing, at least for me. Check out www.ledtronics.com.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
