Wanted Bucket Seats Where Can I Get Them???
where can i pick up bucket seats for my 87 silverado?? i have a bench seat now and would love to have buckets.. thanks
1987 chevy silverado 6inch lift 36" super swamper tsl |
![]() Join Date: Sep 2000
Go to a locall bone yard look in subberns and blazers and be sheru an get the mounts of the floor for your truck.
72 Chevy short step side with 454 air and tilt. 72 nova project car 63 chevy II drag car Agency Iowa |
www.73-87chevytrucks.com
![]() Join Date: Dec 1999
Blazer/Burb seat mounts won't work on a pick up.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
so what seats will work then???
BAD BOW-Silverado XST
Captkaos adapted some single stand alone buckets in his Blazer.
Where the pics Capt? I have two single stand alone bucket seats from an Astrovan that can be made to fit. You have make bracket for them. Not too hard since the buckets already have a 6"-8" metal base to bolt to. |
#6 | |
Here are the pics of the seats mocked in the floor of my Jimmy: http://www.captkaoscustoms.com/Jimmy/jimmymock.jpg Here are the buckets (Toyota Xtracab) buckets mounted in my pickup (OLD pic) http://www.captkaoscustoms.com/images/sueinside.jpg For both I had to make brackets that would mount them to the floor. I have a set of buckets that came from my Jimmy that need recovering that I will sell and I have a matching console. http://www.captkaoscustoms.com/temp/k5buckets.jpg Reguardless of what you get you will have to make mounts for anything. Unless they are new and you get brackets for the application, or you find a set that originally came out of a pickup.
so could i take a set of bone yard jimmy seats or blazer seats and take the brackets and make it work?? i cant have the seats stationary incase my girl friend who is vertically challenged drives the truck.. does it matter if the seats come from a full size or s type? thanks again for the info!! the seats that u put in yourtoyota are what i am looking for!! where did those come from? thanks again
#8 | |
That picture isn't a Toyota truck, it is a 1973 C10 pickup with Toyota Xtracab seats mounted in it.
I have a set from a 75 chev pickup, saddle colour, with mint console, door panels, gauge bezel. I may split them up. Check the parts board.
I used bracket out of a suburban and seats out of a Ford Aerostar van. If you want some picts email me and I will email them to you. The suburban seat mounts work perfectly, there is one piece of metal that you have to cut out and bolt in your truck. When you look at the frame setup in the suburban you will see what I am talking about.
1972 Chevy C-10 Short Stepside 6Cyl, 3 spd, not opts (Current Project) Now a 2004 SSR 5.3L with 4L60E Now Ididit tilt- ps, pb 2002 Saturn L200 2006 Toyota Highlander HYBRID |
