Old 06-06-2006, 10:07 PM   #1
billsbowtie
billsbowtie's Avatar
Some Stuff I Am Taking Off The 72 Gmc F/s
gauge dash bezel driver shape $25.00
billsbowtie is offline   Reply With Quote
Old 06-06-2006, 10:08 PM   #2
billsbowtie
Re: Some Stuff I Am Taking Off The 72 Gmc F/s
pic. 2 of dash bezel.
Old 06-06-2006, 10:11 PM   #3
billsbowtie
sunpro gauges water temp,and oil press. looks like everything is there it was hooked up when eng. was removed driver shape $20.00 shipped for both.
Old 06-06-2006, 10:12 PM   #4
billsbowtie
a no name tack $20.00 shipped in the u.s.
Old 06-06-2006, 10:14 PM   #5
billsbowtie
cig. lighter has some over spray on it $10.00 shipped.
Old 06-06-2006, 10:15 PM   #6
billsbowtie
heater control fair shape has 1 broke leaver $15.00 plus ride.
Old 06-06-2006, 10:16 PM   #7
billsbowtie
pic.2 of heater control.
Old 06-06-2006, 10:17 PM   #8
billsbowtie
brake booster with brackets working right now $50.00 plus ride.
Old 06-06-2006, 10:18 PM   #9
billsbowtie
pic.2 of booster/brackets.
Old 06-06-2006, 10:41 PM   #10
chevdanbarnett
chevdanbarnett's Avatar
hay bill let me know how the inwells are ok when you get thet far thanks dan
chevdanbarnett is offline   Reply With Quote
Old 06-06-2006, 10:46 PM   #11
billsbowtie
dan are you talking about the ft. inner fenders ? if so the drivers side looks good but want no for sure till i take it off. the pass. side is bad.
Old 06-06-2006, 11:12 PM   #12
chevdanbarnett
yes the front inwells ok let me know thanks dan
Old 06-07-2006, 06:56 AM   #13
jaros44sr
jaros44sr's Avatar
Hey Bill, Do you have a cross support panel, radiator support? I am looking to buy a new one, but thought I'd check out used ones first!! Thanks Jim
jaros44sr is offline   Reply With Quote
Old 06-07-2006, 12:41 PM   #14
c-1072
hey if you want to seperate the proportioning valve let me know . also i need a good 72 chevy steering wheel .
c-1072 is offline   Reply With Quote
Old 06-07-2006, 04:07 PM   #15
billsbowtie
jaros44 is this the cross suport you are looking for ? the rad. suport is bad.
c-1072 i have proportion vavles 2wd and 4wd $20.00 shipped to you.
Old 06-07-2006, 04:17 PM   #16
farmtruckIII
71 GMC 454/TH400
farmtruckIII's Avatar
Any eyebrows?
"The bigger you are the harder you fall, the farther you walk the longer you crawl."
farmtruckIII is offline   Reply With Quote
Old 06-07-2006, 04:27 PM   #17
billsbowtie
I Haven't Found Any EYEBROWS Yet.
Old 06-07-2006, 06:35 PM   #18
jaros44sr
jaros44sr's Avatar
No, I was looking for the Rad. Support. I guess its bad.
Old 06-07-2006, 09:17 PM   #19
Sgt.Booya
Sgt.Booya's Avatar
Hi, I'll take the power brake booster, bracket, master cly and prop value. I'll also need the longer rod as I'm converting from standard to power brakes. Can you give me a quote with shipping to 14304 please?
If you keep and open mind you never know what might drop in.
1970 Chev C10 SWB, "250 turbo thrift"
Sgt.Booya is offline   Reply With Quote
Old 06-07-2006, 09:52 PM   #20
70Chevy4x4Nut
Hey Bill, will you be selling any parts from the bed? I'm looking for the rear wheel housings, particularly the passenger side but would take both if the price is right and they are in good shape. Let me know
70Chevy4x4Nut is offline   Reply With Quote
Old 06-07-2006, 10:21 PM   #21
billsbowtie
sgt.booya i will send you a pm.
70chevy4*4nut i will be saleing the bed whole.
Old 06-08-2006, 11:55 AM   #22
c-1072
I need a 4x4 w/power disk brakes pm me a paypal adress and i will par tonight . I could use this asap so i would greatly appreciate a quick shipment of the part .
Thanks a lot
Todd
Old 06-08-2006, 12:33 PM   #23
billsbowtie
c-1072 what part are you needing a proportion valve if so i have 1 for a 72 4wd with dis brakes.
Old 06-08-2006, 08:45 PM   #24
badpeanut
Not a bad nut after all..
badpeanut's Avatar
Any exhaust hangers that look like this?
'05 Chevy 2500HD 4x4
'72 GMC LWB 4x2 driver
'72 Chevy LWB 4x4 plow truck
'71 Blazer 4x4 driver
'70 GMC LWB trailer
badpeanut is offline   Reply With Quote
Old 06-08-2006, 10:23 PM   #25
billsbowtie
badpeanut i will check.
