Old 06-09-2006, 09:37 AM   #1
cptstickfigure
Instrument Cluster Dimensions? Pics?
Does anybody have the dimensions on a '60-63 C10 instrument cluster? Bezel and all, not just the gauges.
I've been daydreaming about installing a tach for the past couple of days, but always had the nagging suspicion that the corners of my instrument panel were already occupied. Duh. I've got the idiot light panel, so my fuel gauge is in the upper right and the temp light is upper left.
I figure if I have to replace the whole panel, I might as well look into using the '60-63 piece, which is much nicer looking IMO.
I've never actually seen the older dash in person, so any pictures of the dash, gauges, instrument panel, and how it all fits into the edges of the cab would be very helpful.
cptstickfigure is offline   Reply With Quote
Old 06-09-2006, 10:53 AM   #2
60-66 Nut
Professional Beer Tester
Re: Instrument Cluster Dimensions? Pics?
From your description, it sounds like you have a 64-66 truck. The 60-63 instrument cluster won't fit, not without some major surgery anyway. The 64-66 full gauge cluster has a place for a tach, since they came with a tach in some of the big trucks. I have seen some very neat looking installations using some of the aftermarket tachs in these clusters. Sorry I don't have any pics, maybe someone can post some for you.
60-66 Nut
60 Ford F100 Custom Cab
61 Apache Short Fleetside
64 C10 Short Stepside
65 C80 409 V8 5spd(X-Firetruck)
83 GMC 350 Olds Diesel
85 GMC Short Bed
86 GMC Short Bed
90 GMC R3500 Crew Cab
92 GMC 1500
60-66 Nut is offline   Reply With Quote
Old 06-09-2006, 10:59 AM   #3
kwkenuf
Retrofit Management
kwkenuf's Avatar
Or you could do this....
Oh, and before anyone says anything, the Buick horn button will be replaced...
My retrofit fleet
-1966 Suburban 2002 Tahoe drivetrain, firewall, floor, chassis and interior in progress
-1965 C-10 shortbed stepside, 2003 5.3/4L60E conversion. Power steering, tilt wheel, power front disc brakes, 2.5/4 inch drop, relocated fuel tank and battery, 2002 Silverado buckets and console. Swap Pics
-1968 Camaro 95 LT1/4L60E lots o' mods Web Page
-1961 Corvette project Corvette Corrections frame, C-4 suspension and brakes, 02 LS1/T-56, Never ending body workPics
kwkenuf is offline   Reply With Quote
Old 06-09-2006, 03:26 PM   #4
cptstickfigure
Yup. I do have a '64, but it's not the full gauge cluster (see below). I had a feeling the 60-63 cluster would take some surgery. I've also considered using an aftermarket panel and gauges, but I really like the idea of borrowing different pieces from the same family/era. Just trying to get as much raw data as possible before I decided one way or the other.
