Old 06-06-2006, 04:06 AM   #1
67ChevyC10Stepside
67ChevyC10Stepside's Avatar
tranny transfer case and rear ID
k...first we have a 1ton crew cab dually....it has a iron transfer case with 2 lo 2 hi neutral 4 lo 4 hi....i've never seen one like that...on the back of it the input shaft looks different than the other ones we have...i have a pic of it and a pic of the other iron one....next....our 87 we got had a 4 speed in it with the 4th being overdrive....i've never seen another like it what is it?....then lastly what are these rearends?
67 c-10, 400 SB, TH350, 4.10 gears, Blazer tank,camaro tach, sidemarker fuel fill (soon)
WTB: stepside parts, 67 front end parts, 67 small window cab. posi for 3.73 or 4.10 for 12 bolt and 10 bolt.
67ChevyC10Stepside is offline   Reply With Quote
Old 06-06-2006, 04:07 AM   #2
67ChevyC10Stepside
Re: tranny transfer case and rear ID
hmm...it says my pics have to be below 100 KB? how do i make them that small?
Old 06-06-2006, 08:37 AM   #3
Jonboy
Slots go on anything!
What year is the truck? It sounds like a 205 to me. There "should" be an ID tag on the backside of the case.
1974 Jimmy- 5.3/4L80e/NP241
Jonboy is offline   Reply With Quote
Old 06-06-2006, 09:44 AM   #4
67ChevyC10Stepside
79 for the one ton but we have 2 iron ones...that look the same....but one splits 2 wheel drive and one doesn't....
Old 06-06-2006, 03:34 PM   #5
BigDan3131
BigDan3131's Avatar
The rearends are either GM 14 bolt or Dana 60-70s
BigDan3131 is offline   Reply With Quote
Old 06-06-2006, 03:56 PM   #6
Jonboy
the full time case is most likely a 203. The pattern from the top is hi Loc, hi, N, low, low loc for a 203. I am not sure what visual clues to look for; I usually look at the shift pattern to try to get close. The 203 case is cast iron, chain drive. The 205 is cast iron, gear drive. The 208 and 241 cases are aluminum, chain drive. I think the input will be different depending on auto or stick applications.
Old 06-06-2006, 05:16 PM   #7
Slonaker
Insert Witty Text Here
Slonaker's Avatar
Assuming you are not a Mac user, you can use Microsoft Paint. Even better than that is Irfanview, an excellent free image utility available at www.irfanview.com.
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 06-06-2006, 05:16 PM   #8
67ChevyC10Stepside
yeah that's how it is....hi loc hi n low low loc.....it's in a 79 1 ton crew cab dually with a 350 TH400 and dont know the rest....i have pictures of all this if i could just figure out how to post them isnt a dana 60 axle really valuable? how do i identify it?
Old 06-06-2006, 08:47 PM   #9
67ChevyC10Stepside
i have irfanview but how do i choose image size in KB?
Old 06-07-2006, 02:13 AM   #10
67ChevyC10Stepside
so how do i ID them? and what kind of tranny is the 4 speed with 4th being overdrive?
Old 06-07-2006, 03:20 AM   #11
67ChevyC10Stepside
from what im gathering of this overdrive transmission is...it was made by chrysler corporation..it's based on the a-833 transmission in the hemi cars...shares the dimensions of a muncie and has a my6 code....anyone else know anything?
Old 06-08-2006, 03:29 AM   #12
67ChevyC10Stepside
noone?
Old 06-08-2006, 10:56 PM   #13
67ChevyC10Stepside
you guys are really good at this
Old 06-08-2006, 11:48 PM   #14
79BIG10
I'm back with 2nd truck!
79BIG10's Avatar
Not sure on the tranny but here's a link to ID your axle. http://coloradok5.com/axleguide.shtml
1979 Chevrolet Bonanza Big10 "Tootsie Roll"
1985 Chevrolet Silverado (wife's)
Member of the Southern Bowties Club
"Don't underestimate how sexy a fat man who drinks to excess can be." Homer Simpson
79BIG10 is offline   Reply With Quote
Old 06-09-2006, 12:05 AM   #15
magnethead
7000 #'s of american IRON
magnethead's Avatar
use http://www.photobucket.com .
a 4x4 dually will have a dana 60 front and either corp 14 bolt or dana 70 rear.
if 2WD is plit i/Lo, it's a 203 i think. If it's only 2WD hi, it's a 205.
as far as transmission, what does the pan look like? (again, picture....)
magnethead is offline   Reply With Quote
Old 06-09-2006, 01:09 AM   #16
pumpkin
pumpkin's Avatar
No pics? Most likely its a 205 t case, with a 14 bolt rear end.
pumpkin is offline   Reply With Quote
Old 06-09-2006, 01:16 AM   #17
pumpkin
pumpkin's Avatar
Where I am, d60's rears go to the scrapyard, d60 fronts are $1000. and up.
Old 06-09-2006, 10:30 AM   #18
67ChevyC10Stepside
i cant figure out how to get the pictures below 100KB....i have pics of everything just cant figure out how to post them
