Old 06-09-2006, 11:07 AM   #1
makovai
makovai's Avatar
Vacuum issues - help me gents
I've got a vacuum issue that really sucks (sorry i had to open with that line)
My rig is making a loud hissing noise that is only there when i don't step on the brakes. As soon as i brake even a little bit, it goes away. I popped the hood and its pretty loud but i cant seem to find it. Does this sound like maybe i broke a diaphram in my booster? It's driving me nuts.
If it aint broke..............fix it till it is.
www.fast77.com
1972 - 330 hp crate, 11" lift with 39x18 mickeys.
3/4 ton, cross steer, 4 wheel disc brakes
1996 Z71 w/ 35's
makovai is offline   Reply With Quote
Old 06-09-2006, 11:32 AM   #2
Burt4x4
Burt4x4's Avatar
Re: Vacuum issues - help me gents
Could be?
What I would do is get a can of carb cleaner, fire up your rig and now spray the fluid around your booster, being careful and watch were you spray, when you hear your rpm go up you have found the vacume leak..depending on were it is will steer you to the fix
Good Luck
Burt
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
Old 06-09-2006, 12:38 PM   #3
HuggerCST
HuggerCST's Avatar
Yep, you need a new booster! You can also pinch the vac. hose to the booster with pliers while the engine is running to verify it, but I'm sure that's what it is.
Wynne
70 CST short fleet Hugger orange & white, 350/350, ps, pb, air, tilt, tach/vac/speedwarning, original buckets, AM/FM, oak bed floor, shoulder belts, 3.5"/5.5" drop, 20" American Racing VN425s.
Build thread
53 Chevy shortbed
69 Camaro
Click here to subscribe
Chevy GMC International Truck Club Louisiana Charter Member
http://www.louisianaclassictruckclub.com
HuggerCST is offline   Reply With Quote
Old 06-09-2006, 12:45 PM   #4
Jason915
I would isolate the problem by disconnecting the vacuum line to the booster and see if it goes away. Also a cheap vacuum gauge is very helpful.
Good luck
1971 GMC K1500 SWB Fleetside, 4" skyjacker softride and, 14 Bolt FF, HD Dana 44 4.10's
1970 K5 TBI conversion lifted etc SOLD
1968 C20 camper truck SOLD
“To ban guns because criminals use them is to tell the innocent and law-abiding that their rights and liberties depend not on their own conduct, but on the conduct of the guilty and the lawless.” Jeff Snyder
Jason915 is offline   Reply With Quote
Old 06-09-2006, 12:51 PM   #5
JMac11
JMac11's Avatar
Replaced all my vacuum lines and Booster, truck would not idle. Quit counting the turns of the idle screws at 6. Takes about 12 foot to replace all your under dash ones.
JMac11 is offline   Reply With Quote
Old 06-09-2006, 01:08 PM   #6
makovai
makovai's Avatar
funny thing is i have a vacuum gage. Put it in couple weeks ago in the blank spot next to the oil pressure gage. It really doesn't show that im low on vacuum, although my brakes have never work very well. I wrote a thread a while back about switching to a hydraboost. I bought one but never installed it. Maybe I've have a bad booster since i bought the rig.
Beside...... brakes are overatted, all they do is slow you down.
www.fast77.com
1996 Z71 w/ 35's
Old 06-09-2006, 03:53 PM   #7
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Sounds like now is a great time to swap to the hydro set-up..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 06-09-2006, 04:37 PM   #8
Burt4x4
Burt4x4's Avatar
What I did is upgrade my booster to 1ton.
1/2ton truck have a single diaphram booster were 1ton uses a double.
WOW! I can actualyl lock up my 35" swampers now. HUGE improvement.
Simply when to Autozone (they carry AC Delco) and ordered a Master/Booster set for a 1972 K30 1ton 4x4 p/u.
My brake are better than ever!
Burt
Old 06-10-2006, 08:27 AM   #9
makovai
makovai's Avatar
damn...i got to this post after i bought a replacement booster. That was the problem. The brakes work a little better, but the biggest thing is the vacuum leak is gone. Now i kinda wish i would have bought a 1 ton booster. I cannot nor have i ever been able to lock my brakes up.
www.fast77.com
1996 Z71 w/ 35's
Old 06-10-2006, 11:26 AM   #10
DEFIANT NCC-74205
DEFIANT NCC-74205's Avatar
I put in a 1 ton too. Got it a while back in the yard. Works good. I've considered hydro-boost, but abandoned the idea. Just more hoses to leak and when your power steering pump takes a dump you loose your brakes. Another way to decrease brake effort is to get a master cylinder with a smaller bore. That's right a smaller bore increases brake pressure and reduces effort.
Well at least you fixed your vacuum leak. Another good way to check for vacuum leaks is by squirting water. Works like a can of carb cleaner, but makes a nice slurping sound when you find the leak and it makes the engine rpm drop when sucked in.
"If at first you don't succeed, keep on sucking 'till you do succeed" - Curly Howard
To go with honor and courage, a far and wonderous distance
DEFIANT NCC-74205 is offline   Reply With Quote
