06-08-2006, 11:30 PM | #1 |
Rolled on Paint Club
Another trailing arm thread
I discovered a few weeks back that I needed new arms, the old ones were so rusted that I could see through them from the side. Being short on cash, but having a LOT of welding wire compelled me to repair the ones I have. I started by pressing out the bushings and drilling out the rivets to separate the sections. The rust had literally bowed the centers out as it expanded over the years. I hammered the lumps out and cleaned off all the rust with grinders and wire wheels. Then bolted the halves back together with 3/8" bolts and welded the seams together top and bottom. Then cut out a 3' section of rot in the center and butt welded in a 1/4" section of steel I cut out of a piece of 4" angle. The soft bolts will come out and be replaced with G8 bolts in the future. I gave 'em a coat of POR15 and then a coat of ZeroRust. I dont think I will be worrying about rust again
Bob
1970 GMC 1500 swb fleetside SB 355ci. Smog heads Summit 1102 cam Performer intake and carb. Finally in about 1 piece in the yard. |
06-08-2006, 11:39 PM | #2 |
Truck junkie
Re: Another trailing arm thread
Looks good...probably less flex being welded that way too. Did you get any pics of em after they were painted? Either way nice work!
06-08-2006, 11:40 PM | #3 |
Looks pretty good. If thats mig welding, your going too fast, and mabee a bit cold.
06-08-2006, 11:42 PM | #4 |
Too bad you don't live in Texas...I got an extra set.
Kelly '05 GMC Sierra SLE Z71 Bone stock except for new bed rail caps. |
06-09-2006, 06:22 AM | #5 | |
Bob
06-09-2006, 10:18 AM | #6 |
PROJECT 7DEUCE
They look good,what is zero rust????
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
06-09-2006, 11:31 AM | #7 |
