River life......
rocker panel, pillar questions
Is there anything wrong with welding the front floor support to the fwd pillar instead of bolting it? I ask because my lwr pillar is about a .5" short for drilling and bolting. Also on the rear of the rocker, will welding hurt anything?
Re: rocker panel, pillar questions
No their is nothing wrong with it as long as you get everything lined up right before you weld. What I do is screw it all (kick panel, inner rocker, post bottom, outer rocker) together and fit the door and make sure it all lines up properly. Once it does then you can remove the door and unscrew it all and start welding the first piece on and for the second piece just insert the screws into the same hole and then weld that piece on. Repeat for any other pieces and you are done. No that being said if I can bolt it together I do but most are so rusted out that I end up welding them back together once all rusted metal is removed.
If you want take a look at project penicillin on the truck page. I go over alot of this with pics. Also in the FAQ page is a inner rocker write up that I just did last week with more pics. Hope this helps. Kevin LFD Inc |
Are you sure your door lines up correctly, my 'A' post is patched at the bottom and if it isn't exactly right my door hits the front of the rocker panel. I didn't have a 1/2" to play with. Just finished the floors and all yesterday and I can't count how many times I mounted and dismounted the door to get the lines correct.
The last time I saw pics. of your truck it looked complete except for the grille. Are you doing floorboards now? I just started putting the front of the engine back together and ran into a problem. The pulley on the power steering pump doesn't line up, seems to be cocked about a 1/2". Guess I'll have to start a thread for help! How close is the truck to getting finished? What's the next project? Jim |
#4 | |
River life......
I still have to finish the front clip, floors, wiring, paint, and interior. When I get done with this one, Im getting another 1st gen or a 67-72 truck. Good luck on the power steering (I forgot I have to add that to mine also)
#5 | |
My son just came home from college[ grad.] he said he would give me 1 month of help, so we're shotting to get the whole project down and onthe road. Jim |
#6 | |
As far as your door/rocker problem if you can not rais the door any more you may want to take a block of wood and a BFH and put a slight wave in the front of the rocker to clear the door. I have had this problem with alot of new rockers. It is not a "A" post problem but a rocker fitment problem. The new rockers do not have as much of an indent as the stock ones did. Kevin LFD Inc. |
Actually, he had a plant managers job on west coast even before he graduated. Probably made alot more money than I do! Came back to the east coast, missed the family I guess. He had a job lined up but it fell thru, so offered his help, heck of a lot better welder than I am. So I do the mechanics and he does the metal work.
I'll try that BFH trick as I don't want to scr*w around with my new doors to much, all my lines look great except the rocker panel, about a 1/4" clearance. Disto, you had a pic. of your daughter a while back, that's where my boys started. Now they actually do some work, and thier good at it |
