10-09-2002, 12:52 PM | #1 |
Small rust holes, weld or bondo
On the sides of my stepside, where the fenders meet the bed, there are small rust holes. after I remove the "bad" metal I am left with a hole about 1 1/2" by 2". Should I go ahead and weld
these up? Or get out the old bondo. Its in small square patches where the lip of the fender met the bedside so I didnt really have to remove that much before I hit good solid, still holding orig paint metal. I'm leaning twards welding, just wanted to know what the pros do for small holes.
Rod Childers '71 C10 Stepside |
10-09-2002, 01:19 PM | #2 |
WELD - Definitely weld. I wouldn't take any chances with Bondo cracking loose later.
Smooth68's Web Site WTB 64-66 project or frame/cab, SWB or LWB...I have the fever! Whatcha got?? '68 Short Step - Shaved Body, Soon Bagged - SOLD Driver-2004 GMC Z-71 Ext-cab |
10-09-2002, 01:25 PM | #3 |
now thats a true COON DOG
I would have to agree! Welding is the ONLY way to go! I would cut a small piece of rust free sheetmetal, thats the exact size of your hole. Then very slowly tack weld it in place! Just becarefull not to warp the area your working on! Good luck! -Brian
current project 67 402BB stout th350 3.08's with a locker. Plan on tubs 18.5's out back! (thanks Burnsman!) 71 SWB Stepside, was a 250, now is a 402 Big Block with 4 speed and 3.73's ( was crushed by a tree, bed sold, motor pulled) was my first truck!... oh well... 72 LWB 4x4 350 4-speed 3.08's posi wearing army olive drab green (SOLD!) 68 BURB 50TH LOOKALIKE work in progress, soon to have 250-I6 with a 3-speed on the tree 4.11's and posi ( currently sitting in back yard tarped awaiting time, $$$, and lots of love!) 67 1 TON- work truck 396 sm 420 4-speed, flat bed 4.57 gears "big red" (my first landscape truck, very rusty and crusty! but still gets the job done when needed!) |
10-09-2002, 01:32 PM | #4 |
Thats what I was thinkn. I just wanted to be reassured. Making a small patch to fit close enough to make a good butt weld is a PIA!
Any hints on butt welds appreciated. I have a lincoln weld pak 100 and I think Im going to try .030 flux core. Better put on the asbestos undies, cause every one is going to say "use gas"
10-09-2002, 02:19 PM | #5 |
Just Another Crazy Canuck
if you dont wanna make a patch to fit find a peice of aluminum big enough to cover the hole and start welding and the weld wont stick to the aluminum
you can also use the block as a doly to pound the welds down(hammer weld) so there is less to grind
1985 454/465/205, 38.5x11-16BOGGERS soon to be installed: 14bDETROIT,Edelbrock Performer cam,intake and valve springs,Comp roller tips,MSD HEI |
10-09-2002, 03:18 PM | #6 |
Fabricate till you "puke"
"aspestos undies"....hehe! You can turn the heat down with gas, but i think its doable with flux core. I like to fit a but weld patch as tight as possible, then only weld a spot at a time...... & let it cool,dont get it too hot & you should be ok. good luck......longhorn
10-09-2002, 06:06 PM | #7 |
Definitely weld to do it right. I bonded up some trim holes on the Jimmy 15 years ago and some are cracking but some are not. I was on a SERIOUS budget at the time. Since then, I bought a square chassis punch from Eastwood for doing small holes. It is MUCH easier to cut a square patch than a round one! I then use some Harbor Freight butt weld clamps to hold it in place to tack. Then pull the clamps and stitch it up! I like the flap discs you can buy for grinding the welds down.
10-09-2002, 09:06 PM | #8 |
I hope It will weld OK. I have welded 20ga with good results using .035 I hope with .030 it will even do better.
10-09-2002, 09:51 PM | #9 |
Why don't u use the gas?I was welding without the gas for a long time finnally went and bought the conversion kit man what a difference that made
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327/4L60 |
