Old 06-12-2006, 10:09 AM   #1
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
My next project (like I need another one!!)
Well, I should really be working on the 68, but this thing has been staring at me for awhile now. I bought it from board member Kaycee about a year or so ago. I bought it mainly for the 305 V-6 engine, as a buddy needed one. I figured I would part the rest of it out and be done with it. Well, my buddy decided to sell his truck, so the GMC just sat.
I decided I would put it back together and sell it and use the money to put into the 68. I hadn’t really looked the truck over until this weekend, and it is surprisingly solid! No rust in the rockers or cab corners, but the inner rockers need replaced on both sides. The outer rockers are solid, but caved in. The bed needs a new drivers bedside, and I will need a driver front fender and a grill. I will also replace the front lower section of the right bed side. The rest of the body work should be fairly easy to fix.
It needs a trans and a rear end, both of with I have. Along with some other things like brake lines and small stuff I have from the 68's old frame, I think I have all my bases covered.
The plan is to fix all the rust, replace the bad sheet metal and fix the rest, install a TH-350 that I have, swap out the rear-end, and paint inside and out. I am not real crazy about the original color, so it will probably come down to a coin toss between red with a white roof, or medium green and a white roof. Then either some factory ralleys or some chrome somethingorothers.
Here is what I am starting with. Sunday I got the right front fender off, the grill, and got most of the interior stripped out. I’ll keep updating this thread as I go along.
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 06-12-2006, 10:12 AM   #2
glock35ipsc
Re: My next project (like I need another one!!)
A couple more:
Bob
Old 06-12-2006, 10:26 AM   #3
Yukon Jack
Yukon Jack's Avatar
Looks like you have a good plan on what you want to do - that always is wise. Keep us posted.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 06-12-2006, 06:05 PM   #4
chevy_fatman
Where's my beer?
chevy_fatman's Avatar
Is that the original color coral pink?
Paul
How do you make the invisible, visible?.........You take it away.
chevy_fatman is offline   Reply With Quote
Old 06-12-2006, 07:09 PM   #5
glock35ipsc
I'm not sure if it is coral pink, or a very faded color called palomino tan. The glove box sticker is gone, so I really don't know.
Bob
Old 06-12-2006, 07:23 PM   #6
glock35ipsc
Now that you broght it up, I went out and looked. There is a definate masking tape line in the door jambs, and over spray that fades as if the truck was painted with the fenders off. I also found a run, and it looks like the A-pillar was also white, along with the upper door frames.
As a side note, I found the following scribbles on the firewall:
CM1590D - 124
Tinded W/S
Radio 557
PG 498
992
Bob
