Old 06-11-2006, 08:56 PM   #1
76bonanza
76bonanza's Avatar
electric fan question
Those that have electric fans and thermostatic switches what temp is good to set them to come on with? (with sender on outside of radiator not in the coolant.)
1968 c10
lowered 3" 4"
355/Th400 built by Hatfield racing in joplin MO
76bonanza is offline   Reply With Quote
Old 06-11-2006, 09:56 PM   #2
TugOwar
Re: electric fan question
I don't have electric fan setup, but I want to do the swap one day so this interests me as well.
I'm going to take a wild stab and say, if you have a 180* thermostat, for instance, then set the fans to come on at 180*. As soon as the thermostat opens and that hot coolant leaves the block and enters the radiator I want it to start cooling.
But then I have no experience with senders outside the radiator.
TugOwar is offline   Reply With Quote
Old 06-11-2006, 10:31 PM   #3
kelsfine69
18 Till I Die
kelsfine69's Avatar
I have an adjustable sensor with the probe in the rad fins. It is kinda a once its set, its set, thing. works great. When the rad gets hot the fans come on, driving down the highway the rad cools off, then the fans shut off, they are not needed. What i like the best is once you shut the truck off the fans run until the rad cools down, about 30-60 seconds then they shut off automaticaly.
2011 GMC Acadia
1969 GMC BBC LS7
2007 GMC Crew Duramax
1987 Camaro Iroc 350 Tuned Port Injection
42000Km
1987 Chevrolet Silverado 350 TBI
1987 Chevrolet Silverado 350 TBI(yes 2)
Take me drunk, I'm too home...
kelsfine69 is offline   Reply With Quote
Old 06-12-2006, 04:27 PM   #4
see ten
WTB this ad
see ten's Avatar
This man is on the money! You want to stand outside the truck holding the upper radiator hose. When you feel it get hot (thermostat open) this is the point you want your fans to kick on.
see ten is offline   Reply With Quote
