Cabfloor Q....
Hi all, I've been looking all over for a part to replace the part of the cab floor that is tied into the cab corner and the rocker panel and sits on the rear floor support. Surely someone else has had to replace this
Re: Cabfloor Q....
I think they call that a dog leg. Did you check gmcpauls.com or mothertrucker.com or calssic industries.
Alan |
Re: Cabfloor Q....
yeah checked all of them, no luck
![]() Join Date: Jul 2004
Re: Cabfloor Q....
One of these ??? Try www.manestruckparts.com
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 Last edited by Green Machine; 06-12-2006 at 12:38 PM. |
Re: Cabfloor Q....
hey green machine, does the piece in the bottom pic go all the way to the back of the cab and behind the piece in the top pic? if so then yes that is what i need
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Re: Cabfloor Q....
Try wes at classic heartbeat I am sure he has em...
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
LAIDOUT
Re: Cabfloor Q....
If you are referring to that section of floor just inside the cab corner, I had to make my own piece for that area. I think I used some of the cutoffs from the front floor pan, bent it to shape and welded it in, no tough to do. They might make a piece for this area, but I didn't find it when I ordered my new metal.
Re: Cabfloor Q....
BigSky, that is exactly the peice I'm looking for. I can't beleive nobody sells them
LAIDOUT
Re: Cabfloor Q....
I suggest that you work installing the other replacement pieces first, and by the time you get to this back floor piece you will certainly have the skills to cut and shape the right chunk of metal!
Re: Cabfloor Q....
You can get this for $299.95
![]() ![]() But if you floor is really gone it might save you some work. Its a newer product offering from this year from Goodmark Industries. http://www.goodmarkindustries.com/HomePage.html
If you keep and open mind you never know what might drop in. ![]() 1970 Chev C10 SWB, "250 turbo thrift" ![]() |
Rolled on Paint Club
![]() Join Date: Jan 2006
Re: Cabfloor Q....
The lower pic in Green Machines post is the part you are looking for: rear cab floor patch. It is missing in the pic below, waiting to be welded in. I mistakedly got them from LMC, and they were as thin as tin foil. Got a new pair from GMC Paul and they were heavier gage. The passengers side has the indentation for the jack to rest in.
Bob
1970 GMC 1500 swb fleetside SB 355ci. Smog heads Summit 1102 cam Performer intake and carb. Finally in about 1 piece in the yard. |
Re: Cabfloor Q....
I pieced mine together with 14 ga. scrap steel. Worked like a charm.
1970 GMC 1500 Custom Original 350/TH350 Victoria, BC, Canada You can wish in one hand and crap in the other. See which one gets filled first. |
Re: Cabfloor Q....
bobd the lower pic in greens post looks like it doesn't wrap around the back side of the rear pillar. southpa i pieced mine together also but it didn't turn out as well as yours. sarge!!! man i dont really need a whole floor pan but man that is cool. i kep hearing goodmark is making these but your the first to post a pic and price, i couldn't even find it on their website. that may be the way i go for that price
#14 | |
Re: Cabfloor Q....
2013 avalanche 5.3l 1971 Gmc 350 1958 Gmc fleetside |
