Old 06-14-2006, 03:34 PM   #1
5150
C10 Club Tennessee
5150's Avatar
Brakes Hard as a Rock
Don't have any problems stopping, but they are hard as hell. Just manual brakes, but I do have the big 20's. Just thought I'd ask why they would be hard as rock. New pads, new shoes, and got plenty of fluid.
Bryan
www.gmtruckshow.com
Project "Andes"-Halen's First Truck
Project: Patina Burb
for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4
5150 is offline   Reply With Quote
Old 06-14-2006, 03:42 PM   #2
Oldtruckfanatic
Truck junkie
Oldtruckfanatic's Avatar
Re: Brakes Hard as a Rock
There are a couple of things that can cause a rock hard pedal depending on whats been done to the system. If the brakes seem to work well my guess would be the master cylinder bore being too big for the system. Power brake setups use a 1" or larger bore in most cases and manual brakes generally use a 7/8" bore or less depending on the system. the larger bore means more volume of fluid but less overall pressure (the volume being the reason the pedal travels less) and a smaller bore means more overall pressure but less volume meaning the pedal travels further to move the amount of fluid it takes to apply the brakes. (this is just one cause) you also can't rule out a tight pivot for the pedal arm, blockage in the system, a faulty residual pressure valve in the master cylinder or combination valve etc. Hope this helps.
Oldtruckfanatic is offline   Reply With Quote
Old 06-14-2006, 05:07 PM   #3
truckdude239
truckdude239's Avatar
my manual brakes are hard just tought tthat was they way they were
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 06-14-2006, 07:50 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
on these trucks, the master cylinder is the same regardless of power brakes or non power brakes.
If they stop the truck fine, you are able to lock them up, and you can do all this with one fiit... then it sounds about right to me.
Remember, these were built when men were men.
Old 06-14-2006, 08:31 PM   #5
5150
C10 Club Tennessee
5150's Avatar
like I said I stop, now if I didn't then I'd be complaining. Just wanted to know why they were so hard.
Bryan
www.gmtruckshow.com
Old 06-14-2006, 11:32 PM   #6
jimfulco
You might just be used to having some air in the hydraulics, which will make the pedal spongy.
jimfulco is offline   Reply With Quote
Old 06-15-2006, 02:34 AM   #7
jhow66
jhow66's Avatar
Also the 20's act as a longer lever making it harder to stop the wheel from turning.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
