06-15-2006, 11:24 PM | #1 |
how cold does you a/c blow ?
mine with the stock system except a sanden 134r compressor max's out at 60 deg's
any body else got a better temp using 134r? Last edited by rage'nrat638; 07-12-2007 at 07:03 AM. |
06-15-2006, 11:25 PM | #2 |
Rebuilding 1 at a time
Re: how cold does you a/c blow ?
Just depends how fast I am going and how many windows I have down. HA HA
71 cheyenne lwb 383 stroker 2004R tranny Factory ps, pb, air http://smg.photobucket.com/albums/v3...t=101_0059.jpg 66 Nova SS L-79 327 m21 http://smg.photobucket.com/albums/v3...t=101_0042.jpg |
06-16-2006, 12:37 AM | #3 |
It should get colder that? I think my 72 was getting 47 degrees out of the vent when I recharged. Thats with 134r
06-16-2006, 12:48 AM | #4 |
Speed Limits...yeh right
39f with an outside temp of 78f
1972 3/4 ton 4x4 LONG BED 1940 Chevy Pickup 1970 El Camino Pro Street 496BB w/NOS |
06-16-2006, 12:49 AM | #5 |
If I want it really cold, I'll take my mother-in-law for a ride
06-16-2006, 01:06 AM | #6 | |
06-16-2006, 03:51 AM | #7 |
Who charged the system? How much r134a charge was used? Was the system flushed before the new compressor was mounted? How much oil was put in? Was the expansion valve replaced? How about the reciever/dryer? All of these will affect performance.
A common mistake is to look up the propper r12 charge for that system and charge the same amount of r134a. The result is poor cooling due to an over charged the system. The rule of thumb is that the r134a charge is only 80% of the former r12 charge. A propperly charge r134a system should run about 18 to 23psi at the suction port with the rpm held at about 1200 with the discharge pressure under 400psi. There are many reasons for an A/C system not to work well. Hooking up a good A/C manifold gauge set is a good place to start looking for the answers. |
06-16-2006, 09:57 AM | #8 |
I agree with above. I have a stock system, get 45 degrees at the right vent. Sounds like your system is overcharged. Bleed a little off at a time from the low side and see if cooling improves. To check you will need to raise your RPMs to about 1500 and put a thermostat in the vent. At idle cooling is a little slack.
06-16-2006, 05:19 PM | #9 |
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
If your useing the whole factory system with R134 you can tweak the POA to work better with R134.
Check out this thread in the Blazer forum http://67-72chevytrucks.com/vboard/s...d.php?t=202734
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension. Petrolia,Ontario,Canada but working in Port Huron,MI. See ALL my Blazer pic's HERE |
06-16-2006, 10:14 PM | #10 |
I adjusted my poa valve on my stock 71 system and converted to 134, I get 42-44 out of the left hand vent. You have to adjust the poa valve if you are switching to 134 or it will not work as well.
Jeff
I'm not a pessimist, I'm just optimistic that bad things are going to happen. 1971 Cheyenne Super K10 - tilt, cruise, air, am/fm, tow hooks, factory buckets! 1986 Jeep J10 pickup, - 5.3L Vortec with 4L60e and NP241. |
06-17-2006, 07:45 AM | #11 |
and which way would a guy adjust this poa valve. right to tighten or left to loosen ?
and how much? thanks mark |
06-17-2006, 09:39 AM | #12 |
a stock poa is set somewhere around 29 psi at sea level. This needs to be adjusted to around 26.5 psi @msl. Best way is to get a fitting that will screw into the female end of poa. I don't know the size but it's like 1" or 1.25". This fitting needs to have a 1/4" opening so you can place the end of an air hose into it and blow air. So I guess this fitting would be 1" or 1.25"threaded male x 1/4" threaded female. At the same time hook your guages to the poa and measure pressure. Hook the guages to the two side openings on the poa one at a time until your guages read a psi. Continue adjusting screw untill guages read 26 - 26.5 psi.
By the way, you may have to take the poa to the hardware store and try fittings until you find one that fits. |
06-17-2006, 11:26 AM | #13 |
WTB this ad
Well at 11:15 it was 83* in the shade and I went out to take a reading for you fellas. It's a Vintage Air surefit system that uses 134a. I have to tell ya that looks like a solid 39* maybe 38* ........at idle sitting in the sun. We very seldom turn the fan speed to high.
06-17-2006, 11:32 AM | #14 |
we got 39* air consistently w/my bro's 69, we used 1990 C10 serp belt setup w/R4 comp, Old Air POA eliminator & Old Air two electric fan setup, stock GM everthing else. Some tinkering & fiddling w/charge was neccessary. Rage you need more airflow thru rad or less freon. brian
06-17-2006, 12:00 PM | #15 | |
Granddad's Ol' Truck
1971 Chevrolet Custom 10 short step-side 2005 GMC Sierra SLT 2500HD crew cab 2wd [I]1971 Chevrolet Custom 10 Deluxe lwb fleet-side |
06-17-2006, 04:15 PM | #16 |
I've had it as low as 37, driving at about 40 mph with an ambient of about 100, very low humidity. That's using an Old Air system. Too bad these old cabs aren't insulated very well! I'm working on that now.
69 C-10 LWB, 350, 700r4, 3.73 posi-traction, front disc brakes. Built for the desert- She can take the heat! Vivat Rex Chevus! |
06-17-2006, 04:28 PM | #17 | |
But that is nice and cold!
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension. Petrolia,Ontario,Canada but working in Port Huron,MI. See ALL my Blazer pic's HERE Last edited by BobbyK; 06-17-2006 at 04:29 PM. |
06-17-2006, 07:34 PM | #18 |
I am a Referee of life.
If I can't turn the cab into a meatlocker on the hiway somethings wrong with the AC.Usually carry a blanky for the wife.I don't have AC in the panel yet but will probably use a regular Old Air or Other Pick-up unit with a street rod unit added in the rear.The tech guys I have asked seem to think one compressor will run both.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
06-18-2006, 01:39 AM | #19 | |
PROJECT 7DEUCE
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
