Old 06-18-2006, 08:41 AM   #1
entourageguy
Yellow truck club
entourageguy's Avatar
Headlights
After about 1/2 hr with my lights on they start to flash on and off. The oncoming traffic loves this as there must be a cop ahead!! I'm sure there is a circuit breaker type fuse some where. The rest of the lights (dash etc) are not affected. Is it on the light switch itself? Can it be changed or is it time for a new switch?
Thanks in advance for the help and Happy Fathers Day to all the dads. I'm off for a round of golf with my 12 year old.
Brian
Brian ......
My hub garage address
http://www.hubgarage.com/mygarage/59apache
I gue$$ everything has it'$ price
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
350 700r lokar shifter
power MII front end, shockwaves
tilt, 4 wheel discs
4-link and bags
10 bolt limited
entourageguy is offline   Reply With Quote
Old 06-18-2006, 08:50 AM   #2
Igotachevyor2
Apache Club
Igotachevyor2's Avatar
Re: Headlights
ive had dimmer switch problems like this
58 CHEVY APACHE I 74 CHEVY C-10 I 78 K-10 donor truck I 89 SONOMA
My Trucks Apache Sitting Idle MySpace
Project Dad's Truck (74 C-10 to K-10 conversion)
Igotachevyor2 is offline   Reply With Quote
Old 06-18-2006, 10:57 AM   #3
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: Headlights
There is a thermal type breaker on the light switch. When you look at the switch it has a set of points on the top. Thats the breaker. It could be bad or you have a bad connection somewhere making the load on the switch higher than normal. Things to check would be dimmer, the switch it self, headlight connectors. If you leave the lights on and they start flashing the bad connector should be warm or hot if its a connector.
Old 06-18-2006, 11:55 AM   #4
Jebb1978
Jebb1978's Avatar
Re: Headlights
I was thinking the same thing as dwcrs hopefully it's just a loose connection somewhere causing the the breaker to overheat. I had a simular issue with my 1978 and all it took was me taking the headlight plugs off and on to clean up the connection. Good luck, let us know what happens with it.
1959 GMC project
Jebb1978 is offline   Reply With Quote
Old 08-13-2006, 12:35 AM   #5
entourageguy
Yellow truck club
Re: Headlights
Was poking around under the dash thinking I'd replace the headlight switch but it looks like a new one already. It has a fuse instead of the old style breaker. Still not sure what would be causing the headlights to both go on and off.
Brian
Brian ......
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
tilt, 4 wheel discs
4-link and bags
10 bolt limited
Old 08-13-2006, 09:40 AM   #6
Jebb1978
Jebb1978's Avatar
Re: Headlights
Have you messed around with the plugs on the headlights at all?
1959 GMC project
Old 08-15-2006, 04:53 PM   #7
entourageguy
Yellow truck club
Re: Headlights
Have not looked at plug for headlights. I thought the flashing of headlights would be the circuit breaker on the headlight switch going on and off. But since there is a new switch there with a fuse should it not just blow? What would be causing the lites to go on and off??
Brian
Brian ......
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
tilt, 4 wheel discs
4-link and bags
10 bolt limited
Old 09-17-2006, 01:20 PM   #8
entourageguy
Yellow truck club
Re: Headlights
Well the headlite switch seemed to be getting quite hot so I replaced it. Also cleaned the area the switch makes contact with behind the dash and no more trouble. Did a 2 hr drive in the dark and no more flash...
Brian ..
Brian ......
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
tilt, 4 wheel discs
4-link and bags
10 bolt limited
Old 09-17-2006, 02:03 PM   #9
texascowboy593
texascowboy593's Avatar
Re: Headlights
Glad to hear it worked out for you!
"The rays of light thru the Shiner Bock bottle make me wanna turn the key and put down the throttle...and get lost down 35" - Jason Boland
www.YouTube.com/user/593Films - Watch My Videos!
1977 Silverado K10
2014 Dodge Durango (Wife-mobile)
2008 Dodge Ram Lone Star Edition (Daily driver)
texascowboy593 is offline   Reply With Quote
