![]() Join Date: Dec 2004
79 Chevy Pickup C-10 for parts
Burgandy exterior/interior. Body has a newer paint job from a few years ago. Cab is almost rust free. Rust starting just a little in cab corners.There is a little rust on pass side inner rocker and floor support. Cab is 95% solid. I believe previous owner (owner before guy I bought it from) replaced everything (floors,Rockers, cab corners, doors and fenders. 3" Fibergalss cowl hood(bolt on w/ pins in front).Bed only has rust over the wheel wells on both 1/4's(Bubbling started .Pass side 1/4 has a little rot behind rear wheel.). Bed has bedliner with a huge bed toolbox(could fit a full size floor jack in it w/o handle) mounted at front of bed and diamond plate bed rail caps. All Cab and radiator support mounts were replaced with urethane mounts. Located in Trenton,NJ (609)481-8811
2) Custom rear bumper w/ drop hitch $75 3) (2) Doors (new) (manual windows) $125 ea. Comes with new mirrors 4) New fenders (2) $60 ea. 5) grill $40 5) headlight bezel trim (plastic) $20pr. 6) windshield $75 7) Rolling chassis w/ cab(with glass) and bed( no doors, seats, steering column,front clip, tailgate, rear bumper) $250 with title.Cab is 95% solid. 8) Alpine pull stereo $40 9) Big bedTool box $100 74"W x 28" deep x 18" high 11) 2 1/2" Dynomax w/ dumps $125 12) tailgate $60 13) rear slider glass $50 14) 12 bolt rear w/ 2.76 gears (open diff.)$100 15) Bucket seats (out of late 80's -early 90's Blazer/Suburban) $75 16) center console $ 30 17) overhead console $40 18) 305 motor out of an 87' Trans Am GTA runs good ( mileage somwhere b/t 65k-80k) needs valve seals. $100 for long block 19) factory gauge cluster w/ tach $50 20) Newer Holley 600 Vac. secondaries carb w/ electric choke $150(sale pending) 21) Edelbrock performer manifold center bolts holes were opened up to make it fit an 87-up SBC (Supposed to fit pre 87' SBC) Will still fit older SBC. $40 (sale pending) Make offers on this stuff. Parts need to go. Last edited by dpmalibu; 06-19-2006 at 09:16 AM. |
Re: 79 Chevy Pickup C-10 for parts
ttt
What does the center console look like? any pictures?
83 C10 Stepside (SOLD, it was a blast!) 383 MASS-FLO EFI/TKO II 600/3.90 Posi 10 bolt S475 and C4 DM running, fine tuning turbo= ![]() Douchebag Racing: Runs Fine all the Time |
Is a 87 is a roller motor?
Give me your email address and I'll send you some pics. I am not sure if it is a roller motor or not. I believe the TPI motors cam with roller cams.
Motor is a 305. guy I bought it from lied about the motor.
http://newjersey.craigslist.org/pts/166605664.html
Here are pics of the truck. Make some offers. Truck is stripped already. Nice cab with very small amount of rust. Very solid.Motor stripped. Runs good but smokes( long block only). Other parts are separate. Headers are trash.Bed is decent .Floor solid but needs some 1/4 panel patches around wheel well. Last edited by dpmalibu; 06-04-2006 at 08:34 PM. |
I would be interested in pics of the SS454 wheels and the overhead console
PM sent
ttt New prices. Make offers.
Stepside Fanatic!
Intersted in the overhead console. Can you send pics? Thanks
Stepside Fanatic!
I'm looking for a cheap pair of front coil springs to heat and drop the truck, got any?
I don't have any coil springs. I am going to sell the rolling chassis for the cab so I need the front suspension.Pm me your email address.
Pm sent RE: intake.
#15 |
pm sent back.
#16 |
Oh,you can't buy that new
![]() Join Date: Apr 2000
DP, did the tach work? ,
fenders & doors were aftermarket? cowl hood pretty straight for F/g ? what did you buy to drive now? I got a solid little 74 SWB down here that all your parts would look good on - i'll make you a good deal on it :-) Check out the link below also for local gathering at unknown date as of now . DAVE http://67-72chevytrucks.com/vboard/s...43#post1724343
"been there, done that, ruined the T-shirt". 2007 LBZ GMC Sierra, ECSB 2006 LM7 RCSB Silverado 98 Vortec project. 94,3500,6.5L 4L80 81 SWB GMC POS finally gone ![]() 73 Pinto, stock, w/CragarSS's-eww ![]() LOTS of Cummins trucks. Last edited by crossy; 06-08-2006 at 12:53 AM. |
#17 |
Fenders and doors are aftermarket. All fit and lined up good.Fiberglass hood is straight no chips or cracks etc. tach works.Bought a 84 3/4 ton Suburban 4x4 to drive while I build my 75 3/4 ton 2WD Suburban. I will have to pass on your 74 short bed. I have my hands full right now.
#18 |
TTT. Make offers must clean out garage.
#19 |
I'll take the tach dash if still available. DAVE
"been there, done that, ruined the T-shirt". 2007 LBZ GMC Sierra, ECSB 2006 LM7 RCSB Silverado 98 Vortec project. 94,3500,6.5L 4L80 81 SWB GMC POS finally gone ![]() 73 Pinto, stock, w/CragarSS's-eww ![]() LOTS of Cummins trucks. |
