Old 10-09-2002, 10:57 PM   #1
Question I6 & Ac
I've been seeing alot on the board about AC model trucks and was wondering do any of you folks with the 6's have AC on your truck?
Was it even an option for the sixes?
I was thinking about it for mine (Yankees in the south need it), but was wondering if the brackets and all even existed for it, and how much it zapped the six's power?
Palf70Step is online now   Reply With Quote
Old 10-10-2002, 12:44 AM   #2
guitarman
Do it well or don't do it
guitarman's Avatar
Yes they had air as an option on the sixes. Rare as "chicken lips" Now as far as brackets I would check on-line with Vintage Air for a complete after market a/c system.
Try to be the person your dog thinks you are.
Excellent paint and body site:
http://www.autobody101.com/
Visit my Web Site
http://home.attbi.com/~agfosteriii
guitarman is offline   Reply With Quote
Old 10-10-2002, 07:18 AM   #3
JJR
JJR's Avatar
As mentioned, it was an option and I have seen people selling the brackets on the board. I have found a ton of A/C brackets for 250's in early to mid 70's Nova's but their block is different than the one in my 70 truck. To use the Nova brackets your block need to have a (for the lack of a better term) tab embossed in the block next to the timing chain cover that mounts one of the support brackets. If your block has this you can use the Nova brackets which are much easier to find than the truck bracket. I have not checked with the aftermarket A/C companies to see if there system can be used on a 6. All the ad's show V8 applications but it would seem like they would have to have a I6 set-up.
FOUNDING MEMBER OF THE DRUM BRAKE CLUB
Second Owner 70 C-10
Second Owner 93 GMC C1500
Third Owner 99 C2500 Crew Cab Short Bed
JJR is offline   Reply With Quote
Old 10-10-2002, 11:59 PM   #4
Rod
Here a rarer set up ... factory V6 with ac.
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
