Old 06-21-2006, 12:56 AM   #1
13lazer
13lazers' blazers
13lazer's Avatar
electrical gremlin
i posted another thread on this problem when i thought it was my starter. now i know i have a short somewhere. my problem started immediately after i accidentally reversed polarity. everytime i think i fixed it, my battery is completely drained the next day. i have troubleshot and eliminated the alternator and my voltage regulator circuit. i plan on pulling fuses tomorrow to try to find the circuit. if anyone can think of a weak link i should start with i'd appreciate it. i really hope i dont have to go into my steering column. i have several complete wire harness' for my truck. i wonder if it will just be easier to replace all of my wires?
1970 2wd blazer
1972 1ton blazer 4x4 in progress
1966 mustang coupe (modified)
1985 c20 suburban tow rig
1996 462 ranger with a 150 efi merc. a former B.A.S.S. tournament boat
almost all exempt from california smog laws intentionally.
13lazer is offline   Reply With Quote
Old 06-21-2006, 01:05 AM   #2
Oldtruckfanatic
Truck junkie
Oldtruckfanatic's Avatar
Re: electrical gremlin
Check the horn relay.
Oldtruckfanatic is offline   Reply With Quote
Old 06-21-2006, 01:36 AM   #3
MisterMan
MisterMan's Avatar
charge batt, popo caps slowly and carfully, check 4 bulbes, bubbles = dry cell
MisterMan is offline   Reply With Quote
Old 06-21-2006, 09:42 PM   #4
13lazer
13lazers' blazers
13lazer's Avatar
i think it was a crossed jumper in the mess where i had wired my tranny lockup, glove box light, map light, and electric choke. when i pulled the mess apart my test light i had rigged to hang from my rearview went out. i don't want to get too confident yet, i have been wrong before. the horn relay was fine and my batteries are all optimas. i'll know tomorrow
1970 2wd blazer
Old 06-21-2006, 10:18 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
It was the choke.
You probably had all that wired up to a constant hot, right? That way the glove box light comes on when you open the box after you've parked. The choke is supposed to be on a switched circuit.
