Old 06-20-2006, 03:59 PM   #1
76bonanza
76bonanza's Avatar
hood hinge replacement
I have two newly powder coated hood hinges on there way to me. What is the best way to replace them with out getting every thing out of wack? Remove hood or not.
Any tips would be helpful
1968 c10
lowered 3" 4"
355/Th400 built by Hatfield racing in joplin MO
76bonanza is offline   Reply With Quote
Old 06-21-2006, 07:31 AM   #2
76bonanza
76bonanza's Avatar
Re: hood hinge replacement
no one?
1968 c10
lowered 3" 4"
Old 06-21-2006, 06:51 PM   #3
stope4
Be careful and remove and install one hinge at a time. Mark where the old hinge is located with a marksalot or similar. You will need your shoulders to hold the hood while inserting the bolts to hand tight. Then you're home free.
stope4 is offline   Reply With Quote
Old 06-21-2006, 07:24 PM   #4
76bonanza
76bonanza's Avatar
thanks stope4 I will hopefully have one helper with me.
1968 c10
lowered 3" 4"
Old 06-21-2006, 10:24 PM   #5
stope4
Make sure your helper is holding the hood at the cowl so it doesn't slip and hit it. Then you need to make sure it doesn't try to flip down in front and bend.
