Rust above windshield inside cab
Is everone having problems with this or is it just me? How are you handling the problem? i know you can get replacment parts but welding this area could be tough! could change hole top!
KIDs in the front seat cause accidents,Accidents in the backseat cause KIDs! ![]() ![]() ![]() ![]() |
its all about the +6 inches
Re: Rust above windshield inside cab
Many ppl just junk the cab once that happens, but they did just start selling this item a few years ago.
The sealant in the drip rail on top gets dry and shrinks over time, seems to be more of an issue on south and western trucks. Then, it rains and get wet inside there. Then, once it starts to rust a little, the rust holds the water when it rains again, and it evolves into a real seriouse issue. Personally, I would have to inspect the whole thing inbetween the inner and outer cab roof before I'd go replacing that panel... it would suck to replace it and then drop thousands in paint and body, only to discover that the surrounding area was already rusting, and only pops through AFTER you've spent your life savings. |
that cab on my 69, which is 67 cab, is rusted all the way across bout an 1" thick. i took a wire whell and cleanin out all the bondo for the po and painted it to match the rest of cab, can hardly tell its there. chris.
its a work in progess. 71 c-10 lwb, in the middle of frame off restoration. 69 c-10 swb, drag truck, 406 sbc, balanced, comp 292 cam, ported, polished, gasket matched, and bowl blended pro comp 210cc heads, 2.02/1.60 ferrea valves,1.6 roller rockers, re curved hei with msd 6al box, 2-step rev limter, accel 300+ wires, ported victor jr intake, holley 750 double pumper carb, dynomax 1 5/8 headers, 4 spd munci m-20 with super case and iron midplate, mr. gasket vertigate shifter, 5.38 pro gears with full spool, 33 spline moser axles and c-clip elimators, line-loc, 5 gal fuel cell, holley blue pump. ![]() ![]() 7.807 @ 88.37mph 1.60 60FT 80 g-20 van, tow rig, cammed 305, th350, 10 bolt 88 jeep wrangler, dd, 258, ax-15 swap, 4.5" lift, 33x12.50's, lockers, 3.55's |
I have the same problem at first it was devistating. (My truck is from Houston and salt gets in everything down there.) I found a 71 AC cab for a replacement. it is in a lot better shape. My 72 cab is rusting so bad around the windshield pull the rubber back a little and the rust falls out aroud the seal. I hated replacing it but it seemed to be the only logical desision.
1972 Cheyenne 402 LWB 2005 Silverado X-Cab 5.3L 2004 John Deere L120 20HP B&S |
![]() Join Date: Feb 2001
I believe Calvin told me a few weeks ago that they are making a replacement for that area or maybe even the whole inside roof.
Personaly if you replace the cab or just the bad area I would make sure you get a good rust product up in side their before repainting. I like to tip the cabs over and shoot por15 (or =) up the A-posts,thru the visor holes, light hole in the rear of the roof and up the B-posts as well. Just soak the roof area and the A & B posts with product to treat and seal all the metal and then clean out the drip rails and do the same out their. This should help give a life time of protection since the factory did nothing to help make these areas last. I had to replace my California cab because of way to much rust and when I fould a good solid replacement for it I built the Tip & Flip just so I could get into very area posible before spending $$$ on paint and labor only to have it happen again. People always think of rust treating other parts of their truck but this is one of the most over looked area on these things.
Kevin LFD inc. |
Insert Title Here
Heres some pics of mine
BOBBY _69 SWB_ 1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all << |
Insert Title Here
I was going to get this from GMCPauls some time doen the line
Hey is that a pic of my cab? your are missing the rust falling out like mine
A lot of the cabs seem to have the problem! Sad thing is lower part of my cab is in real good shape!shame, shame,shame!!
#11 | |
Insert Title Here
Cantankerous Geezer
Here's my writeup on installing the patch without welding.
http://www.myoldtruck.com/vboard/showthread.php?t=7009
Fred There is no such thing as too much cam...just not enough engine. ![]() Last edited by Fred T; 06-22-2006 at 11:44 PM. |
On the college boy budget...
Mine has the same issue, it's made sealing the windshield a pain. The rust on my cab isn't as bad as what 1LoC10 has shown but my windshield will leak in a massive downpour.
-'68 C10 short/step- 350/350 |
Formerly yellow72custom
Mine has it not only there, but above the BACK window too...needless to say, it is junk.
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride. '70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck. '97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg |
#15 |
Car Truck Bike Nut
Yup same problem on my 70 project and my parts 72, 70 even has it above the doors. Luckily, my 68 driver is pretty good. Havn't decided how to repair it yet, I can get a good roof section for $50, might as well chop the top if I'm gonna go to that much work.
Snow free Florida panhandle, don't miss Indiana winters Temp in Suffolk Virginia, Sentenced 2 to 5 years LOL 68 shortfleet project 94 3500 TD dually ![]() so many cars so little time 72 K2 CST 2WD Blazer ![]() |
#16 |
mine are all rusty onthe bottom sides but the roofs are stilll good
common sense isn't so common anymore |
#17 |
Just hang'n around
I get a little water through mine when it rains. Has caused the floor to start rusting. I'm afraid to start fixing it. The project might be bigger than I am.
Driving a '68 Chevy C20 and a '93 Astro Van. Lots and lots of mileage that I deduct each year. |
