Old 06-01-2006, 03:03 PM   #1
Blizz
Blizz's Avatar
what kind/size bolts
do i need to put a dbl wall hard top on my 72?
Blizz is offline   Reply With Quote
Old 06-01-2006, 04:04 PM   #2
71jimmy
71jimmy's Avatar
Re: what kind/size bolts
OK, I'm not buying or selling. This is free advice!!!!!!!!!!!!!!!!!!
All of the bolts for the hard top (double wall, not sure if there is a difference for single wall) are 5/16". The bolts for the bed rails I'm using are 1" long, and the 2 center windshield frame bolts are 1" long. The bolts that go through the visor hangers are 2.5" long. The bolts should be tappered on the end, so that they can locate themselves into the nuts.
'71 Jimmy, 350, SM465, NP205, 2in Tuff Country lift, 33s on rallies, TBI, softtop and hardtop
"If life was fair you'd be able to afford one of each and a garage large enough to house them all."
71jimmy is offline   Reply With Quote
Old 06-01-2006, 07:25 PM   #3
Blizz
Blizz's Avatar
thank you very much.
'72 K5 CST Blazer 4x4 in perpetual progress
'96 2dr Tahoe 4x4 daily driver, Black Bear Performance tune, 285-75-16 Nitto Grapplers, Magnaflow muffler, K&N Air filter, Bilstein Shocks.........E-fan, DT Tri Y or Pacesetter LTs coming soon
Old 06-01-2006, 07:28 PM   #4
Blizz
Blizz's Avatar
does anyone sell a hard top bolt kit??
Old 06-01-2006, 10:52 PM   #5
makovai
makovai's Avatar
I just did my single wall and put 5/16*18x1" stainless bolts (or better known as 5/16x1 coarse thread) that i bought at the local hardware store. Even if there was a kit out there it would cost way too much. Just go by them in your hardware store. I used stainless cause i have fresh running water in my rig. (leaks like crazy)
If it aint broke..............fix it till it is.
www.fast77.com
1972 - 330 hp crate, 11" lift with 39x18 mickeys.
3/4 ton, cross steer, 4 wheel disc brakes
1996 Z71 w/ 35's
makovai is offline   Reply With Quote
Old 06-22-2006, 03:17 PM   #6
Blizz
Blizz's Avatar
can i get these at Home Depot?
