Old 06-18-2006, 08:36 PM   #1
Jeffs65GMC
4 headlights > 2
Jeffs65GMC's Avatar
New project 65 GMC
Well, got the truck home and work has started. It had two flat tires, so I ran over to a buddies to pick up some rollers. He had some old 33's off his jeep and a set of blazer rally rims, so I decided to check it out. The truck needs a motor, so it's high in the front, and there is a buick 455 in the bed, so it's low in the rear. I couldn't get the tires on the back due to the sagging, but up front they look hot. I've got a 10 bolt front laying around, and I'm VERY tempted to swap it in after seeing the stance. If not, I'll go with 31's on the same rims (or 5 lug if I get a complete donor truck for engine, brakes, power steering, etc).
1965 GMC 1000 fleetside (for sale)
1989 Jeep Wrangler (currently torn down, will return again)
1998 Jeep Cherokee (daily driver)
Jeffs65GMC is offline   Reply With Quote
Old 06-18-2006, 11:30 PM   #2
Jeffs65GMC
4 headlights > 2
Jeffs65GMC's Avatar
Re: New project 65 GMC
The more I think about it, the more I'm liking the 4x4 swap. If I do, I will be taking lots of pictures and documenting my progress. I've written some tech articles for another site, so I'll try and show the easiest way to do it with basic tools. From mocking up, it's an easy DIY swap if you have a welder/buddy with a welder. Stay tuned!
Old 06-22-2006, 04:52 PM   #3
jgrh64
Prestige member Old Farts Club
jgrh64's Avatar
There is a guy on this site who put a 500 caddy motor in his, buicks tend to be a little weak in the bottom end.
Hey sombodys gotta do it!
jgrh64 is offline   Reply With Quote
Old 06-22-2006, 05:10 PM   #4
Frizzle Fry
Frizzle Fry's Avatar
Cool. I say do the swap. Longbeds look better lifted than stock or lowered anyway.
Frizzle Fry is offline   Reply With Quote
Old 06-22-2006, 09:57 PM   #5
Jeffs65GMC
4 headlights > 2
Jeffs65GMC's Avatar
First steps are gonna be getting it on good tires and putting a motor in it. It's ready to go for a 350, so that's gonna be the plan.
After that, I'm gonna patch up the few rust holes on it (all metal...bondo only for smoothing) and drive it. I'll see about putting together the front axle while I'm enjoying it.
Oh, the rear end is definitely a dana 44...is that a common option? I was pretty surprised when I crawled under to get a good look at it, I just assumed it was the old 12 bolt. Anyone have any info on it? 30 spline like the newer d44's, or is it the old 16 spline?
Old 06-22-2006, 10:27 PM   #6
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Swap it to a 4wd..... Here are a few pics of my buddies truck..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 06-22-2006, 10:32 PM   #7
Jeffs65GMC
4 headlights > 2
Jeffs65GMC's Avatar
Your buddy has deeper pockets then I do
I'll be doing SOA...I like leaves better then coilovers anyway. Looks like he's got some clean fab work though, and should be able to get the crap wheeled out of it...looks like 38's he's running on that thar d60. Mine will be 4x4 to help pull the trailer with the jeep on it out of a muddy parking lot
Old 06-22-2006, 10:45 PM   #8
FRENCHBLUE72
PROJECT 7DEUCE
Yaaa I wish my pockets were that deep too..
MEMBER #6377
Project "7DEUCE"
