Junior Member
differences between C-10 C-20
Since the search won't let you search 3 letters then I guess I must ask... Talking about suspension wise. Frame the same? Does a C-20 have stiffer springs and heavier duty axle and brakes?
Thanks Graham
A good friend will come bail you out of jail, but a true friend will be sitting next to you saying, "That was ****ing awesome." |
its all about the +6 inches
Re: differences between C-10 C-20
a C/20 (3/4 ton) has stiffer springs, bigger brakes, heavy duty axle and hubs and front spindles, a much higher hauling limit (tow and cary) and much lower (higher numeracly) gears.
On the frames, the general frame is the same, however, on trucks with coils/trailin arm suspention in back, there's some reenforcements on the frame that the C/10 (1/2 ton) does not have. Also, no SWB 3/4 tons were made. |
67-72 C-20 have 8 lug wheels
67-70 C-10 have 6 lug 71-72 C-10 have 5 lug
67 C-20 LWB, tilt, speed alert, vac, 454, T400 67 C-10 SWB, factory air with more to follow |
