Old 10-10-2002, 09:07 AM   #1
jmil1974
Ain't we cute?
jmil1974's Avatar
I could use a differential pic
This seems very silly I know but this is one of those knowledge holes I am trying to fill. Does anyone have a pic of their diff with the cover off? I am trying to determine if I have posi or not. I changed the fluid last night and it seems as though I do. There is a housing in there that looks like many I have seen, though it has gears and not clutches. Having never (recently) seen an open diff naked to compare to (or any other for that matter), I am not 100% certain of what I was looking at. I know there were a helluva lot more gears in there than just a ring and pinion (2 or 3 more inside that bell-shaped housing). Any help would be greatly appreciated. It would be of some comfort to know I have posi, even with the way too sluggish 3.07/3.08s. Thanks!
Jason
69 C10 2WD LWB Fleet 350/350 power front disc conversion (6 lug disc kit from gmcpauls) and new engine, PS, A/C, fresh fluids, SHE DRIVES!
FOR SALE $3900
jmil1974 is offline   Reply With Quote
Old 10-10-2002, 09:11 AM   #2
Pont
I need another Barley Pop
Pont's Avatar
Jason, can you get on it enough to break the tires loose? Do you leave two black patches? From what you described, it sounds like a limited slip diff to me. Did you happen to notice a spring pack assembly in the carrier?
Sorry, I can't help with a pic.
67 Short Fleet 4x4
04 Honda CRF450R
89 Toyota 4-Runner
34 Ford 2 door sedan - Long term project
There is a very fine line between "hobby" and "mental illness"
Pont is offline   Reply With Quote
Old 10-10-2002, 09:13 AM   #3
1971Stepside
Almost Satisfied
1971Stepside's Avatar
Unfortunately I don't have a pic here at work to show you, but the easiest way to tell is Jack up both sides and spin a wheel. If they both go I would say you have a posi.
I thought the same thing when I opened up my pumkin, but it was a standard rearend.
I'm sure someone will show you a picture. Check down a page or two as there is always an "identify this rearend" post.
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021.
"I can't complain, but sometimes I still do. Life's been good to me so far."
1971Stepside is offline   Reply With Quote
Old 10-10-2002, 09:26 AM   #4
jmil1974
Ain't we cute?
jmil1974's Avatar
Well, she's up on jackstands at the moment. When I spin one, both spin. I can barely rmember the last time I drove her (2 years+), much less lit 'em up -- though I intend to remedy that in just a couple weeks.
Thanks for the help fellas,
Jason
FOR SALE $3900
Old 10-10-2002, 09:31 AM   #5
Pont
Pont's Avatar
Do they both spin in the same direction, or if you spin one, does the other spin in the opposit direction?
67 Short Fleet 4x4
04 Honda CRF450R
89 Toyota 4-Runner
Old 10-10-2002, 09:52 AM   #6
jmil1974
Ain't we cute?
jmil1974's Avatar
I'll have to double check tonight but I believe the same direction.
FOR SALE $3900
Old 10-10-2002, 09:53 AM   #7
Pont
Pont's Avatar
well, that should take care of that question for ya then. Same direction is posi, opposite direction is limited slip.
67 Short Fleet 4x4
04 Honda CRF450R
89 Toyota 4-Runner
Old 10-10-2002, 10:30 AM   #8
jmil1974
Ain't we cute?
jmil1974's Avatar
Well, I did a search as suggested and saw a pic that looked like mine, says it's open. Only thing is that I couldn't see in the housing window very well as it was facing mostly up. All I could see was the edge of one spider gear. Ah well, I guess I'll just wait until I drive it and find out for sure since it's already buttoned up and full o' fluid.
Thanks guys!
FOR SALE $3900
Old 10-10-2002, 02:04 PM   #9
Wasted Income
Boosted Member
Wasted Income's Avatar
You can't rely on the directions that the wheels spin to determine if, much less what type of differential you have. An open diff will also spin the wheels in opposite directions when up on jack stands (when you spin one wheel with your hand)
Here is what an ARB air locker looks like
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2023 Ford Explorer ST - Twin Turbskis
2023 Ford F150 RCSB - Whipple Supercharged
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 10-10-2002, 02:04 PM   #10
Wasted Income
Boosted Member
here's a Detroit locker
Turbo diesel
Old 10-10-2002, 02:05 PM   #11
Wasted Income
Boosted Member
here's a Powertrax Lockrite
Turbo diesel
Old 10-10-2002, 02:07 PM   #12
Wasted Income
Boosted Member
and here's an Auburn. GM positraction differentials also look similar to this. If you saw this, you have posi. If you saw 4 gears with a cross-pin inside the carrier, you have an open diff.
Sometimes, under the right conditions, an open diff will leave two blackies, or two burnout marks in the gravel. The only way to be positive is to pull the cover and look.
-Jeff
Turbo diesel
Old 10-10-2002, 02:41 PM   #13
jmil1974
Ain't we cute?
jmil1974's Avatar
67SL1SWB,
Thank you very much!
FOR SALE $3900
Old 10-10-2002, 03:32 PM   #14
Estanley
Estanley's Avatar
I am told it is a:
"That differential is a limited slip or as some people say one wheel wonder. It's not a posi or a locker just a plain differential."
Estanley is offline   Reply With Quote
Old 10-11-2002, 01:16 AM   #15
Wasted Income
Boosted Member
That is not a limited slip. That is your run of the mill open diff (peg leg, one wheel wonder, etc, etc)
-Jeff
Turbo diesel
Old 10-11-2002, 02:48 AM   #16
BobbyK
BobbyK's Avatar
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
Here is what's in my 71's 12 bolt.
It's a Eaton GovLoc.
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension.
Petrolia,Ontario,Canada but working in Port Huron,MI.
See ALL my Blazer pic's HERE
BobbyK is offline   Reply With Quote
Old 10-11-2002, 11:49 AM   #17
mikep
Used to have a truck
mikep's Avatar
On Dana 60 posi's the easist way to tell is by looking at the carrier. The Posi ones have 4 spiders and have bolts on the end of the carrier to disasseble it. Non posi have 2 spiders and have no bolts on the end.. The clutches are burried on either side and are not visible .
No truck :-(
mikep is offline   Reply With Quote
