Old 06-26-2006, 11:24 AM   #1
JameslovesJammie
God Bless Mr. T
JameslovesJammie's Avatar
What does it mean when...
OK,
I jacked the rearend of my truck up to check to see if I have a posi or not. I am on the passenger side, so that's the wheel I turn. The other wheel doesn't turn at all.
So I jack the rear end up a little more, incase the other was stuck to the dirt. I have it up about an inch off the ground and try again. Same thing.
I go to the driver's side and turn that wheel. The passenger side turns the opposite direction. I go back to the passenger side and turn it again...nothing.
Is my rearend screwed up? I thought you were supposed to be able to turn either wheel and the opposite would turn.
Thanks guys!
James
Like a midget at a urinal...sometimes you must stay on your toes.
JameslovesJammie is offline   Reply With Quote
Old 06-26-2006, 11:30 AM   #2
wibilly
wibilly's Avatar
Re: What does it mean when...
i don't think that indicates a problem it a open diff and mabe your breaks are dragging a little on the drivers side
common sense isn't so common anymore
wibilly is offline   Reply With Quote
Old 06-26-2006, 12:32 PM   #3
billsbowtie
billsbowtie's Avatar
IT SHOULD HAVE A TAG LIKE THIS ONE IF IT IS POIS.
billsbowtie is offline   Reply With Quote
Old 06-26-2006, 12:34 PM   #4
billsbowtie
THIS IS THE EASYEST WAY TO CHECK TAKE THE COVER OFF AND SEE IF IT LOOKS LIKE THIS.
Old 06-26-2006, 12:37 PM   #5
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
If you can spin one side with the opposite tire on the ground, it is an open differential. If it is posi, you shouldn't be able to spin one side while the other is on the ground.
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 06-26-2006, 12:45 PM   #6
68speedalert
Semi-Senior Member
68speedalert's Avatar
billsbowtie, that is an accurate way to checkm but WAAYYY overkill.
But your jack under the center of the diff, put the trans in neutral, and spin one of the tires. If the other spins in the opposite direction or the driveshaft turns (without the other wheel spinning) you have an open diff, (which your's is BTW).
With posi or limited-slip, the wheel will spin the SAME direction.
'68 50th Anniversery LWB Custom Fleetside, '77 305 v-8, turbo 350, factory speed alert (still works), '71 drivetrain w/front discs. Some call it ugly yellow, others call it Ochre
'83 Jeep CJ-7, <80,000 miles, original owner
'04 Chevy Suburban, 4x4, 2500, 6.0 ltr, Predator Diablo programmer
'95 GMC K1500 Extended cab
68speedalert is offline   Reply With Quote
Old 06-26-2006, 01:05 PM   #7
71swb4x4
71swb4x4's Avatar
Actually, if it's posi, if it's in nuetral and the rear-end is jacked up. the tires will spin in opposite directions.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 06-26-2006, 01:24 PM   #8
dave666693
dave666693's Avatar
I agree with 68speedalert. If it is an Eaton check the numbers on top of the pumpkin. GMC Paul's website has a referance chart
dave666693 is offline   Reply With Quote
Old 06-27-2006, 01:29 AM   #9
68speedalert
Semi-Senior Member
I won't say your wrong, but I've never seen it. From my experience (25 years wrenching), If you can make the other side turn opposite with a posi......the clutches in the diff are GONE!
With good clutches and trans in neutral, both tires turn the same AND the driveshaft will turn as well.
If you put the trans in gear (or park), a posi rear end will not even let ONE side turn, basically what glock35ipsc said.
Old 06-27-2006, 02:45 AM   #10
SactoJim
SactoJim's Avatar
I'm with 68speedalert.....I've had many posi's (limited slip's) and the quickest way to check was like he said.
SactoJim is offline   Reply With Quote
