Old 06-27-2006, 09:48 AM   #1
pat
pat's Avatar
Rear end U-joint bracket
I switched out rear ends a while back and don’t have the right brackets that bolt the driveshaft U-joint to the rear end. It seems like all the autoparts stores have are the u-bolts. Where can I find these brackets?
68 Chevy 383/350 w/shift kit, 380hp/425ft-lbs, 4.5/5 drop, 17" TT2s
64 Cadillac Sedan DeVille
pat is offline   Reply With Quote
Old 06-27-2006, 12:17 PM   #2
dallas71
dallas71's Avatar
Re: Rear end U-joint bracket
in the help section of most auto part stores....i think there is one to a pack....
dallas71 is offline   Reply With Quote
Old 06-27-2006, 02:37 PM   #3
70rs/ss
70rs/ss's Avatar
Depends on your truck and how you use it, but there are billet caps out there, for not much more than the stock stuff and they will not fail (never say never). Call Summit or Jegs with an application and they can get em to you in 3-5 days.
70rs/ss is offline   Reply With Quote
Old 06-27-2006, 08:57 PM   #4
TravisH
TravisH's Avatar
if you're talking axle saddles I think I've seen them in the LMC catalog
TravisH is offline   Reply With Quote
