Old 10-11-2002, 09:02 PM   #1
bigjimzlll
bigjimzlll's Avatar
transcooler ???
Hi..which line coming from a th350 is out to the cooler? Im thinking about not running it through the radiator..thats what my tranny guy suggest anyways
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
http://67-72chevytrucks.com/vboard/payments.php
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
Old 10-11-2002, 09:08 PM   #2
70shortnphat
"See the U.S.A....."
70shortnphat's Avatar
I Beleive its the upper one but I,m not possitive.
I dont use the one on my radiator and everything is fine.
1970 short bed fleetside
1949 all origional chevy 3600
1974 camaro
Richmond , Texas(just S.W.of Houston)
70shortnphat is offline   Reply With Quote
Old 10-11-2002, 09:34 PM   #3
Gordo
Smile
The trans pumps out the upper fitting. Unless you live in a very cold climate I would run the lines from the upper fitting on the trans to the lower fitting on the radiator, out the upper to the lower fitting on your cooler, out the upper and return to the lower on the trans.
1971 C10 swb stepside 350/700R4/3.73posi (retired as of 4/22/03)
1998 S10 short bed
2002 S10 Blazer
1942 Oldsmobile
1958 Massey Harris Pony
1951 Wife
Killingworth, Connecticut
May those who love us, love us, any of those who do not love us, may God turn their hearts.
And if God is unable to turn their hearts, may he turn their ankles so we may know them by their limping.
A man who works with his hands is a laborer; a man who works with his hands and his brain is a craftsman; but a man who works with his hands and his brain and his heart is an artist.
Gordo is offline   Reply With Quote
Old 10-12-2002, 12:09 AM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: transcooler ???
You ARE running a cooler though, right?
If not you need a new tranny guy.
Old 10-12-2002, 01:51 AM   #5
bigjimzlll
bigjimzlll's Avatar
the tranny guy suggested just using a seperate cooler..he said running it through the radiator actually heats the oil...I have been running it through just the radiator..as the engine heats up, the shifts get weaker..so Im figuring to just running it through a aux cooler instead
Anderson,CA
Old 10-12-2002, 07:38 AM   #6
MOTHERTRUCKERS
If not running it through the radiator it makes no difference as long as it's a tranny line out to the aftermarket cooler and back to the tranny. I run a moroso finned aluminum cooler mounted on a cross bar ahead of the radiator. Not cheap at 179.00 but I tow and haul heavy loads.
Rest in Peace Ed. Thanks for all the good times.
MOTHERTRUCKERS is offline   Reply With Quote
Old 10-12-2002, 11:36 AM   #7
slam33
slam33's Avatar
Your Tranny guy is right. Running thru the rad can magnify problems if your tranny is slipping which creates heat it will transfer that heat to the motor and cause it to heat too. If you have a motor thats running hot you will transfer that heat to the trans . The coolers in the rad can develope leaks also which will screw up your fluid and tranny internals. Both Chevy and GMC finally swapped to aux coolers on there trucks becuse of this. Run a good size cooler all by it's self. I'm doing the big B&M stack plate and I'm upgrading to larger 3/8 tubes.
71 LWB 350/350still working on it but it's going tp be sweet. www.geocities.com/stevemau/slam33page.html
" TARGET=_blank>http://www.geocities.com/stevemau/slam33page.html?1004806705410
</A>
slam33 is offline   Reply With Quote
Old 10-13-2002, 12:50 AM   #8
Longhorn Man
Ok, i agree then, your tranny guy is OK.
Did he sugjest doing a tranny fluid and filter chainge?
It kinda sounds to me like your fluid is thin/broke down/contaminated.
Old 10-13-2002, 12:56 AM   #9
cableguy0
get a tranmission flush that way all of the fluid is changed not just the 4 or 5 quarts in the pan.most shops have a trans flush machine. we charge somethin like 130 for our service which inlcudes changing the filter and doing the fluid flush
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
