Old 07-02-2006, 02:21 PM   #1
RSRXION
RSRXION's Avatar
Dash replacement... anyone ever done it ?
As most of you know my hauler was vandalized many years ago and ALL of the glass and lenses were broken out of it. Apparently they stood and stomped on the windshield and did some pretty significant damage to the top of the dash. The top area where the vents and radio speaker grille is wavy and bent from their destructive efforts. I'm thinking about cutting out the top panel and replacing it but I'm fearful that it may never look right. Any ideas ? Thanks, Dean
RSRXION is offline   Reply With Quote
Old 07-02-2006, 02:28 PM   #2
71swb4x4
71swb4x4's Avatar
Re: Dash replacement... anyone ever done it ?
You should be able to replace the whole dash fairly easily. There are spot welds along the windshield seam, and them a couple bolts on the sides and then it should come out. Bolt the new one on and weld up the spot welds and you should be good to go.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 07-02-2006, 02:34 PM   #3
TugOwar
Many guys on this board have replaced the entire dash, mainly because a previous owner hacked up the radio hole. Never done it myself but as described above it is pretty simple.
TugOwar is offline   Reply With Quote
Old 07-02-2006, 02:42 PM   #4
see ten
WTB this ad
see ten's Avatar
One of the dash pad covers that go all the way down to the windshield might be a good option. I know this is only masking the problem but you know what they say, "out of sight, out of mind".
see ten is offline   Reply With Quote
Old 07-02-2006, 03:51 PM   #5
BigMike
BigMike's Avatar
Here ya go...I replaced my dash a while back, it is not hard at all.
Mike
PO used a jack hammer to make way for a home entertainment center
You can see the holes where the spot welds were
New one welded back in
Front side before I ground down the welds
BigMike is offline   Reply With Quote
