07-02-2006, 12:00 PM | #1 |
how much pinion shim with 6" drop - 68 SWB
I'm running 4" drop springs and I'm ordering 2" drop blocks. Any guesses on how much pinion shim I may need so I can have the right stuff when I'm bolting everything back together?
07-02-2006, 12:15 PM | #2 |
Senior Moment
Re: how much pinion shim with 6" drop - 68 SWB
Read this it may help http://www.2quicknovas.com/happypinions.html
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN 2013 GMC PU, Oldest Son 71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son 2019 GMC Diesil Dually. Youngest Son 2017 Toyota SUV Daughters car 2018 Traverse , Wife’s Ride Pittsburg Ca 94565 |
07-02-2006, 12:34 PM | #3 |
Old Skool Club
Are you running leaf, or coil, springs?
ECE sells 6-inch dropped coils that also mean you need to relocate the shock mounts and to replace the track bar with an adjustable one. Leaf springs don't use the track bar. One option on coil-sprung trucks is the newly available cross member that gives a little more room for the drive shaft to move. Is your driveshaft a one or two-piece unit? 2-piece shafts have more flexibility for dropped rear ends, but can contact the crossmember, in some cases. As far as how much to shim the rear end on a leaf-sprung vehicle, the fine point, as I understand it, are having the correct angles, both at the tail shaft on the transmission and at the pinion coupling on the rear end. One piece drive shafts may make it more difficult, or not. I have a coil spring truck, with 4-inch drop springs and I've had zero trouble with u-joints, vibrations, etc.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
07-02-2006, 07:38 PM | #4 |
Doesn`t lowering a truck put everything more in-line?
