Old 06-25-2006, 12:52 AM   #1
pritch
pritch's Avatar
I knocked the top of my piston off!
I was driving down the freeway today and all of a sudden comes a strange vibration and a general decrease in power. I was still a few miles from the house, and I figured the damage was done, so I limped home and into the shop. The motor sounded real bad, but a noise I hadn't really heard before, coming from either #3 or #4 (straight 6). I pulled out #3 spark plug and checked compression, and it was fine, so I checked #4-and ZERO! I stuck a drink straw in the plug hole and cranked it over-no movement detected. I really thought I threw a rod, but there is no water in the oil, and no hole in the side of the block, so I pulled the head and this is what I found:
I guess I'll pull the bottom end out tomorrow and see what all happenned. I only found half of the lower compression ring, and none of the oil ring so I guess they are down in the oil pan.
Bummer.
'68 Panel
Project Boogie Chillin'
'68 C-10
Ol' Green
pritch is offline   Reply With Quote
Old 06-25-2006, 12:57 AM   #2
TugOwar
Re: I knocked the top of my piston off!
how the hell?
TugOwar is offline   Reply With Quote
Old 06-25-2006, 01:01 AM   #3
jrb71c20
jrb71c20's Avatar
how the hell?
Thats exactly what I'm wondering??? It pratically grenaded
93 Sonoma 2.8/5spd
75 Malibu Classic 350/350
If it don't have round headlights and a carb, I don't trust it!
jrb71c20 is offline   Reply With Quote
Old 06-25-2006, 01:05 AM   #4
pritch
pritch's Avatar
Yeah-I've blown up lots of motors but never had one do this. From what I can see of the cyl. wall, it looks OK. No visible damage to the head, but I have a different one I wanted to put on anyways. I'll know more in the morning.
'68 Panel
'68 C-10
Ol' Green
Old 06-25-2006, 01:28 AM   #5
Fred T
Cantankerous Geezer
Fred T's Avatar
Probably had a crack in the top when it was cast. It's not uncommon in older engines. With enough stress from combustion, the crack finally grew until the piston failed.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 06-25-2006, 09:15 AM   #6
RSRXION
RSRXION's Avatar
It didn't drop a valve ??!?!?!?!?!? I've seen that kind of damage from valve train failure but I don't think I've ever seen anyone pull a piston in two. Were they cast or forged ? I suspect the manufacturer of those pistons would probably like to see it for evaluation. You might send them a note and some photos. If I'd made it, I'd want to know why it failed. Smells like a good opportunity to slide a big block in there ! JMHO, Dean
RSRXION is offline   Reply With Quote
Old 06-25-2006, 09:38 AM   #7
I had a 280Z in Japan do the same thing, but I knew what caused it....water got sucked up through the tailpipe and the cold water hot engine went boom. Hopefully you can still reuse the block. On my z it damaged the walls to bad to correct.
Old 06-25-2006, 09:58 AM   #8
hoser
New or used pistons?
OEM pistons?
How many miles?
Sux that it happen I hope its a easy fix...
If it were my engine I would replace the rest of the pistons.
hoser is offline   Reply With Quote
Old 06-25-2006, 10:25 AM   #9
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Wow thats one for the hey guys look what I blew up wall..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 06-25-2006, 11:58 AM   #10
TugOwar
lol, yup. That would have it's very own display case on the shop wall, lighted even! hehe
Old 06-25-2006, 01:30 PM   #11
pritch
pritch's Avatar
Well I got that rod out. I guess I was pretty lucky, the cylinder looks OK. I would be alot more concerned if I had any plans of keeping this motor. I remembered that when I first bought this Panel, it had a broken piston. I think a PO rebuilt it with the cheapest parts he could find. I'll be putting in a 327 when all is said and done. That's what drives me crazy-the big frame off starts this fall, I just wanted to drive it a little bit this summer but I had to put in a new clutch last weekend just to do that. So I'll slap in a new piston and hope it lasts 'till the road salt flys.
PS-I'll go ahead and keep it on the wall of shame along with some others.
'68 Panel
'68 C-10
Ol' Green
Old 06-25-2006, 03:34 PM   #12
Green Machine
Green Machine's Avatar
In the first pic, does it look like the balance pad on the rod is twisted or not quite square with the block ? Maybe it is the picture angle, but if the rod was twisted before it might stress the piston, but maybe the twist happened when it broke ?
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 06-25-2006, 07:04 PM   #13
chevymad
My brother did that to 6 of the 8 pistons in his 327 impala. There were full ring sets laying in the bottom of the pan, unbroken. No block damage. As with yours the lower portion of the piston held the rod so it didnt rub the cylinder walls. Hard to believe but this engine actually ran into the garage that way. After taking it all apart, we figured it was the huge cylinder ridge and ton of cylinder taper, along with a kid revving an old engine to the moon, that broke the pistons.
A few years ago we also had a Case diesel tractor do that. Cast iron piston. Piston pin almost wore through the cylinder liner. Was a very weird sounding motor. The rings stayed on the piston top and the rod would "throw" the piston top up against the head. .then fire. The top would come slammin down on the rod again. Didnt even bend any valves. I ended up just replacing the one cylinder sleeve and piston.. I'm sure its very well balanced now.. the new piston is aluminum!
70 C10 long fleet, 355/200 4r, 6 lug disc conversion, 3" drop
70 gmc changed to 67/8 chevy, 454 with voodoo cam, th400, all 74 running gear.. in progress
chevymad is offline   Reply With Quote
Old 07-01-2006, 04:03 PM   #14
truckdude239
truckdude239's Avatar
wow never seen that before
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 07-01-2006, 04:57 PM   #15
phantom dually
Project92 SWB stepside
phantom dually's Avatar
Never saw that happen either!
92 C1500 stepside 496 Stroker Competiton Engineering Ladder bars/QA1 coilovers. Dana 60 rear with 4.10 gear and posi. Bonspeed Palisade 20x12 in rear w/335/30/20 and 20x8.5 front w/245/40/20. 5/8 drop with Belltech springs/DJM spindles/drop shocks. WWS Progress thread http://67-72chevytrucks.com/vboard/s...d.php?t=140448
phantom dually is offline   Reply With Quote
Old 07-01-2006, 06:16 PM   #16
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Ouch, was this before or after the other post?
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 07-02-2006, 03:37 AM   #17
89 crew
My brother had a 79 k30 he bought that was rebuilt with imported pistons. 1 piston broke the center of the top, the other 7 when checked had collapsed at least 40 thousandths and up to 120 thousandths. I think his po and yours bought parts from the same place! Oh and to make you feel worse, buying that crap saved $47 for a 400 small block!
89 crew is offline   Reply With Quote
Old 07-03-2006, 08:31 AM   #18
grayw0lf
I burnt the left side off of the #2 piston in my 2.5L, leaving much of it fused to the cylinder wall. But I've never seen the piston seperate.
85' CUCV M1009!!! The newest addition!
6.2diesel, Th400, NP208, & only 36k miles!
70' C-10 LWB Fleetside - Looking good these days!
05' Dodge Neon
88' Winner Escape Sport 1750 - 4.3v6
94' Seadoo SP
84' Honda TRX200, bare nekkid. Just a frame & tires.
Always looking for another project or any good deal!
grayw0lf is offline   Reply With Quote
Old 07-03-2006, 11:14 AM   #19
pritch
pritch's Avatar
The old machinist I go to said maybe I didn't have enough end gap on the rings and maybe one of them put the squeeze on the top of the piston. That's something I'm always carefull to check when I put a motor together, but who knows. Maybe I missed one.
'68 Panel
'68 C-10
Ol' Green
