Old 07-05-2006, 08:53 AM   #26
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: Help wife is PO'd at me!!!!
Originally Posted by Huck
Randy, if the dash cluster has the original printed circuit, it can have a break on any one of the strips and it will drive you nuts.
If you do find a break, they can usually be repaired. Lay a small piece of wire across the break (like a bridge), and solder it on each end.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 07-05-2006, 02:42 PM   #27
Yukon Jack
Yukon Jack's Avatar
Have you tried swapping in a different cluster to help narrow down where the problem is?
I bet it has something to do with those front tow hooks. Better take them off and send them to me for testing.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 07-05-2006, 09:16 PM   #28
chipflyer
chipflyer's Avatar
Hey Randy,
I had to solder a piece of wire onto mine as stocker described, I could bring my meter up and help you find the trouble next time you have it apart. I bet we can fix it!
Jeff
I'm not a pessimist, I'm just optimistic that bad things are going to happen.
1971 Cheyenne Super K10 - tilt, cruise, air, am/fm, tow hooks, factory buckets!
1986 Jeep J10 pickup, - 5.3L Vortec with 4L60e and NP241.
chipflyer is offline   Reply With Quote
Old 07-05-2006, 11:25 PM   #29
jcfoote60
Active Member
jcfoote60's Avatar
Randy, I have a 72 SWB that had similar probs, I chased it for a while and came to the conclusion it was a symptom of 30+ year wiring harness! Everything vibrates with AC and over time that 60hz just makes for loose and corroded copper connections. Additionally your truck has to have good grounds and over time, like everything else on our trucks, gets corosion. I decided that instead of fighting bad grounds and loose connectors to bite the bullet and buy a Painless wiring kit from Summit. Awesome results, bright lights, complete confidence and for $310.00 plus shipping came peace of mind. Take a few days to do it right and follow directions and you will be a happy camper (and the wife). My two cents
JC
jcfoote60 is offline   Reply With Quote
