Old 07-07-2006, 05:04 PM   #1
Baketown Scotty
Junior Member
Baketown Scotty's Avatar
Brake Line Junction, 1969 K5
I recently added longer brake lines in the front from frame rails to wheels due to new lift. Have a leak at the junction block on inside of frame rail, drivers side. It's hard to see with motor and all in the way. I'm thinking I either installed or did not install one of those copper washers in the correct place. Any one have an exploded view of this? Service manual does not show it. Does it go: bolt, copper washer, junction block, etc? Or: bolt, junction block, copper washer?
Baketown Scotty is offline   Reply With Quote
Old 07-07-2006, 05:09 PM   #2
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Re: Brake Line Junction, 1969 K5
Can't help ya on that, but I can say we need more pic's of your rig
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 07-21-2006, 05:51 PM   #3
bjm1981c
bjm1981c's Avatar
i just pulled mine apart for a leaking line and it goes bolt, washer, junction block, and then washer. There should be two washers total, one on each side of the junction block.
'69 K20 w/350 4spd
'67 Camaro w/327 powerglide
'94 MZ470
bjm1981c is offline   Reply With Quote
Old 07-21-2006, 07:14 PM   #4
Baketown Scotty
Junior Member
Unhappy Re: Brake Line Junction, 1969 K5
I guess it comes apart tomorrow to see if I did it right. It's only 107 in the garage. Does NAPA carry those washers? Thanks a lot for the info.
Old 07-21-2006, 07:48 PM   #5
72gmcshorty
72gmcshorty's Avatar
Yes NAPA should have them. They come on that help rack in a little box.
1992 Gmc 2wd
1972 Chevy Blazer 2wd
72gmcshorty is offline   Reply With Quote
Old 07-22-2006, 11:37 AM   #6
makovai
makovai's Avatar
I just bought a kit with braided lines. I'll open it up and scan the directions if there's is a diagram.
If it aint broke..............fix it till it is.
www.fast77.com
1972 - 330 hp crate, 11" lift with 39x18 mickeys.
3/4 ton, cross steer, 4 wheel disc brakes
1996 Z71 w/ 35's
makovai is offline   Reply With Quote
Old 07-24-2006, 11:14 AM   #7
Baketown Scotty
Junior Member
That was my problem. One copper washer missing. Thanks everyone.
