Old 07-07-2006, 06:35 PM   #1
walker
walker's Avatar
Tire size question, for non lowered truck
I have a '67 2wd that has BFG radial T/A's on it. I am tired of dragging the ground over rocks, or getting stuck on curbs, etc. So, I would like to put some larger truck tires on it, but I don't know what size would fit and look good too. I will use 15" or 16" wheels, and was thinking of something in the 29"or 30" neighborhood. I am not adverse to putting in the 3/4 ton springs, or making slight mods to make it work, but I don't plan on going overboard to stuff 35s in. Does any body have some pictures of trucks set up this way?
Andy,Phx AZ
'67 C-10 (Ahhh, done at last. Well there is that disk front end I want to put in and...)
"23 C-Cab-sold
'48 Ford 8N tractor(still working)
'67 Scout(Now on the road)
'70 MG B.-sold
walker is offline   Reply With Quote
Old 07-07-2006, 09:15 PM   #2
truckdude239
truckdude239's Avatar
Re: Tire size question, for non lowered truck
235/75r15 is the size closest to stock tire size
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 07-07-2006, 10:15 PM   #3
jsbgump
Gone Fishing
jsbgump's Avatar
Run some 31 x 10.50 x 15 on it. they fill the wheel well up and look pretty good on theese trucks.
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop Frame of resto has been started
2022 Hyundai Tucson Limited
2019 Chevy Traverse Redline Edition Wifes Ride
Build Thread
http://67-72chevytrucks.com/vboard/s...=1#post3483616
jsbgump is offline   Reply With Quote
Old 07-07-2006, 10:49 PM   #4
camaro__thunder
Epoxy Primer Friendly
camaro__thunder's Avatar
"I am tired of dragging the ground" How low is yor truck ? Current tire size ?
My Project 69 SWB
SHAVED BAGGED DOORED
camaro__thunder is offline   Reply With Quote
Old 07-07-2006, 11:02 PM   #5
HeavyD
HeavyD's Avatar
For stock height I always use 255/70/15 T/A's. Front tires in this pic are 255's, back are stock 235's.
"You can take the man out of PA, but you can't take PA out of the man"
HeavyD is offline   Reply With Quote
Old 07-07-2006, 11:25 PM   #6
truckdude239
i would recomend the 235/75r15 i got a book at work called old timers fitment guide and it translates most stock 15 inch wheels to the 235/75r15 only reason i recomend it is it get the speedo the closest to being right plus you have a lot more options tire wise to pick from just my $.02
David fuller
2000 Tahoe 5.3l 378
Old 07-07-2006, 11:30 PM   #7
roughedup72
roughedup72's Avatar
heres mine with 285/70/15's on all corners
1972 chevy cheyenne 10,nothing special at the moment,Its a work in progress, Working on the engine, paint and body,engine, paint and body,now its the suspenion, ahh hell I'm about tired of working on it. Maybe it will be a rat rod.
roughedup72 is offline   Reply With Quote
Old 07-08-2006, 11:28 AM   #8
walker
walker's Avatar
Mine looks about like Heavy ds. The problem is that it is pretty rugged terain out here. The other problem is when I eithher get it loaded up, or have a trailer attached, I tend to bottom on the culvert at the end of my driveway.
Andy,Phx AZ
"23 C-Cab-sold
'70 MG B.-sold
Old 07-08-2006, 04:39 PM   #9
1-PU70
1-PU70's Avatar
Here is my C10 with 31X10.5X15. Wheels are 8X15. They are Goodyear HT.
1970 CST/10 402,700R4,3:73 posi,AC,PS,PB,TLT,PW,Buckets with heaters
1-PU70 is offline   Reply With Quote
Old 07-08-2006, 05:03 PM   #10
walker
walker's Avatar
Looks like 31 10.5 15s it is. 1 70PU, have you had any rubbing/bottoming out problems after you put them on?
Andy,Phx AZ
"23 C-Cab-sold
'70 MG B.-sold
Old 07-08-2006, 06:34 PM   #11
mtndewmaniac66
Do the Dew!
mtndewmaniac66's Avatar
Mine also has the height of HeavyD's, but I am running 255/65r15 back and 245-65r15 up front. Stock height tires with a wider tread pattern.
mtndewmaniac66 is offline   Reply With Quote
Old 07-08-2006, 08:16 PM   #12
1-PU70
1-PU70's Avatar
No rubbing or anything.
Old 07-09-2006, 12:32 AM   #13
walker
walker's Avatar
I finally went out and looked at my tire size. Right now they are 255/70/15s. They just seem a bit small to me.
Andy,Phx AZ
"23 C-Cab-sold
'70 MG B.-sold
Old 07-09-2006, 10:38 AM   #14
57sailplane
57sailplane's Avatar
man i run 275/60/15s they look great and fill the rear wheel well. i think you could even go biger like 295/60/15s..
57sailplane is offline   Reply With Quote
