#51 |
14.1 @ 96MPH
Re: 1969 Burb build-up (Bags, 5.3/4L60E, repaint, interior....)
Sanderson's making custom headers for GenIII swaps? I had ECE's Sanderson shorties on my 350 before the swap, loved 'em...I'm using MAC shorties but I sure wouldn't mind going to a longtube eventually
Are they going to be short like the SBC headers, or full-length headers?
Project1970 - LS1 Swap Complete!
#52 | |
![]() Join Date: Apr 2005
I forgot to ask him that. I'll try to find out. Rob
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
#53 | |
www.73-87chevytrucks.com
![]() Join Date: Dec 1999
![]() This is the drivers side: http://www.73-87chevytrucks.com/proj...man_clear1.jpg
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
#54 |
Junior Member
I'm using 2005 truck manifolds and have no issues on the passenger side and will only need minor grinding on the drivers side to get the clearance I need. I'm using the S&P mounts. I tried the EC ones but they told me they are specific to 2 wheel drives and wouldn't work for me.
1972 K/5 4x4, Radixed LS1 6.0, 428HP/445TQ, Lingenfelter GT2-3 cam, WCCH 90mm J-Tube, LS2 90mm TB, Stainless Works Headers, NV4500, 4.56 gears, Detroit Lockers, 14 bolt FF, Dana 60, 4 wheel disk Hydro Brakes, dual electric fans, Autometer guages, 4" lift, Zero Rates, Weld Evo Velocity XT8 wheels, 35x12.5x17 Super Swamper SSR's..... http://s72.photobucket.com/albums/i1...tos/?start=all |
#55 |
o man your truck blows!!! if ya dont mind what did that set ya back..... on mine it looks like the engine sits lower, but that may be my error.... for a fact on mine i needed to grind the upper pass side frame frail about .75 inch in by about 10 inch long. and the dr side i had to notch it for the collecter flange..
#56 |
On my LT1 swap in Project Slow Build I had sandersons build me a set of Semi-shorties andd I also moved my motor back 2" tward the fire wall since their is no dist. to worry about. They also coated my tranny cross member for me when I stopped by to get the first set of trial headers. Great people over their and they are all hot rodders so it made for a fun visit.
PS. the burb is looking great! Kevin LFD Inc. |
#57 |
Got back from vacation and found some more bling-bling on the porch!
Painless 18 ckt harness, lower shock brackest for front shocks (modifying because they hang to low), and sheet metal to fix the floors (thanks Ed, MotherTruckers). I only need about 2 inches from each one (not that I'm complaining).
#58 |
Quick update: Making a little progress but no pics. Pulled old gas tank and fuel lines. (prepping for my ECE SS tank). Got it up on jackstands and will start rocker and floor repair, gas tank lid install and tail light modifications this weekend. Pics to follow.
#59 |
![]() Join Date: Feb 2000
Not sure how I've missed this thread - some cool stuff going on!
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
#60 |
Thanks Yukon, I've been planning this for a year. Hopefully it will move fairly "quickly". I guess I need to come up with a name for this project, but don't have any ideas -- anybody got any suggestions?
#61 |
Questionable
how much for the painless harness - let me know how you like it, how it installs and whether you are required to keep *any* of the old wiring in the truck (if so, what? dome light? anything else?)
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
#62 | |
Rob
#63 |
All Praise RANDY!!
Lookin good Rob, How long did the painless experiment last? to install that is?
I def. need to do this soon too! Bill |
#64 | |
R
#65 | |
Auto wiring is my arch enemy and I know there more than a few of us out here. We'll take all the help we can get.
#66 |
A little more progress. I got the electric gas pedal installed (wish the rest of the project could go this easy!). Lined up passenger side doors to ensure good gaps prior to beginning rust repair. I will start on the rockers and floors this week.........
#67 |
A few more pics for the rust that need repaired. It looks like most of it was caused from a leaky winshield gasket
#68 |
Update: Removed most of the passengers side rocker, part of the floor board and the innner kick panel. I will finish removing the rest tomorrow and then start fitting the new panels.
#69 |
Finally got a little more work done on the rockers/floor this week. I've got everything cut out and most of the new parts fitted. I'll screw/tack them all into place, put the door back on for a test fit, and then if all lines up, time to weld it all up and go to the other side.
#70 |
Just A Tool Hand
Looking real good!!!!!!
:hit: |
#71 |
Anyone notice the white paper outline on the floor? It is/was the build sheet. I couldn't save it and the only thing I can make out on it is the word "FREMONT". This matches the VIN for where the truck was built.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 06-30-2006 at 07:40 AM. |
#72 |
More progress.... Got all floor pieces (rockers/floor/kickpanel) fitted. Now some POR15 to prevent any future rust (hopefully!).
#73 |
Patch Panel for air box (this was a fun one to make
). I also raised the lower shock mount on my StrongArms. They are the lowest part on the front end and I always seem to drag them. I think I still have enough travel in my shocks, but may have to go with a shorter one.
#74 |
![]() Join Date: Feb 2003
real nice...........
1971 K5 CST Blazer 1965 C10 Short bed all original 1949 gmc 100 1968 Honda mini-trail z50a #377 1966 uh 1-D Huey |
#75 |
Slowly but surely making progress. The key for me has been making a little progress every day. I try to get 4-5 hrs on the weekend and at least 1 hr a night.
I didn't have much rust, but it affected 5 pieces that are all tied together creating a multi-dimensional metal jigsaw puzzle. I haven't kept track of my time, but I'm sure it's taken longer than some of our Pro's on this board. It definitely adds to my respect of some the guys that do this type of work with relative ease. After much "ciphering" I have figured out that the inner rockers are shorter on a truck than a suburban (lengthwise and widthwise). So after spending several hours trying to make the repop work, I finally took Rokcrawln's advice and built my own. Rok, not that I didn't believe you, but I had the repop so I thought I would try. I will build my own from now on. When I got bored trying to fit the five dimensional metal puzzle together, I ground down most of the welds on the fire wall. Minimal brain power required to do that!
| Bookmarks |
