Old 07-13-2006, 05:58 PM   #1
74Chevy74
Do Aftermarket wireharness' still need headlight relay mod for headlights???
If I'm using an aftermarket wiring harness, do I still need to do the upgrade for the aftermarket headlights, or will these harness' support them?
74Chevy74 is offline   Reply With Quote
Old 07-13-2006, 08:14 PM   #2
piecesparts
Parts and more parts
piecesparts's Avatar
Re: Do Aftermarket wireharness' still need headlight relay mod for headlights???
I suggest that you get the Aftermarket relay and harness. TWO reasons--1) the wiring harness may support the extra load, but the switch is still the same design inside--so a possible problem. 2) The use of the harness will guarantee that there is a full 12 volts at the headlights, not a percentage like you would have using the full wiring system and running the power through the dash and switch. The bulbs will last longer as well as being brighter.
