07-15-2006, 08:35 AM | #1 |
6 or 12 volts
Hello i'm new to the forum,i just got a 56 3/4 ton that was completly disassembled and as i'm going through the parts the cluster still has the wiring attached to it with the ignition switch. it came w/o a motor or trans,but the switch doesn't have a start detent it just seems to be on or off.i figure i can just get a 56 car switch and run an extra wire.my ? is are these trucks 6 or 12 volts as i'd like to use the original gas gauge and don't want to ruin any thing. this is going to be a big project and the wiring is a long way off but i'm curious.hopefully some pics will follow as it progresses thanks ,bud
07-15-2006, 09:46 AM | #2 |
Re: 6 or 12 volts
12 volts. The truck had a floor push starter in it originally. The only way to use that switch with a modern starter, would be to wire to a push button switch, then to the solenoid.
Good luck, and welcome aboard! Last edited by 5Mike7; 07-15-2006 at 09:47 AM. |
07-15-2006, 09:48 AM | #3 |
Hollister Road Co.
Re: 6 or 12 volts
Welcome to the board.
Its 12 volt with a pedal starter the switch is on, off, and maybe acc. push the pedal to start. You can get a key switch for the starter on what ever engine you get. I used the original gages in my 58 and you can still get replacements for the ones that are broken. keep us updated |
07-15-2006, 02:51 PM | #4 |
Apache Club
Re: 6 or 12 volts
welcome to the board throw some pics up when you can
58 CHEVY APACHE I 74 CHEVY C-10 I 78 K-10 donor truck I 89 SONOMA
My Trucks Apache Sitting Idle MySpace Project Dad's Truck (74 C-10 to K-10 conversion) |
07-15-2006, 04:48 PM | #5 |
Re: 6 or 12 volts
You can buy a new switch from any of the after market venders like, Bothers Trucks or LMC.
Classic Trucks Link http://www.classictrucks.com/feature...uck/index.html 1958 GMC.Project Build http://67-72chevytrucks.com/vboard/s...d.php?t=162816 1966 Chevelle Build http://67-72chevytrucks.com/vboard/s...d.php?t=443576 Video http://www.youtube.com/watch?v=prrNKo8F7Zw#GU5U2spHI_4 |
07-16-2006, 03:13 PM | #6 |
Re: 6 or 12 volts
thanks, here's a pic of the tk and the donor tk
